GPS Mount?
Old Dec 22, 2010 | 09:48 AM
heavychevy7485's Avatar
heavychevy7485
I would not mount it to the windshield. While taking a 1000 mile trip, the suction mount did not stay on long. I put on the fuel cap cover and experienced no issues after that.
Old Dec 22, 2010 | 10:08 AM
Chaffeekid's Avatar
Chaffeekid
Hi, you didn't specify the type of TOM TOM you have, but here is a link to one that I have on my Ultra, see the signature pic for how its mounted. It is also reasonable in price. It mounts easily with only one screw, and locks down tight, never comes off unless you pry it with a non marking pry stick, (Dove bar handle works great
http://cgi.ebay.com/TomTom-Tom-XL-33...item2a09274f64
Sorry you can't see it in the signature pic.
Ride Safe
Old Dec 22, 2010 | 12:02 PM
2011FLHTK's Avatar
2011FLHTK
The suction cup will not hold.
For a cheap solution get a Ram Mount. The whole rig should run you about $25.
Old Dec 22, 2010 | 12:05 PM
sifularson's Avatar
sifularson
Old Dec 22, 2010 | 06:45 PM
RKCjum03's Avatar
RKCjum03
Got mine from The MountGuys. This one holds the Tom Tom securely in the cradle. Very easy to remove and install. Mine is for a 330S Tom Tom. Got the shorter arm and the double ball option. Looked for a while to find one like this. Did not like the the one that just holds it by the speaker on the back with the ring. Below is the site.
http://www.mountguys.com/product_p/ram-b-149z-to8.htm
Old Dec 22, 2010 | 10:02 PM
mcain49's Avatar
mcain49
FWIW - I have a Garmin and use the suction cup to mount on the fuel tank cover. I have used it that way on several trips and not once had a single issue. When I first started doing it I was paranoid about it coming off and checked it very often. It was always secure so I don't worry about it anymore. I like the after market fuel cover mount but don't want to lose the ability to lock my fuel tank cover. The down side is that repeated use of the suction cup will cause minor scratches on the fuel lid if there's any grit on the surface of the suction cup.
Old Dec 22, 2010 | 10:44 PM
FXDXTSport's Avatar
FXDXTSport
Originally Posted by cfdcaptain99
What's the best way to mount my TomTom? Will the suction cup stick to the inside of the windshield or the fuel door? I don't want to spend a ton on an aftermarket mounting system.
Thanks!
My Ram mount works great with the added bonus that I can use it for my Contour helmet cam or my flip camera also (with the proper adapter)
Old Dec 23, 2010 | 12:02 AM
emwolb's Avatar
emwolb
the suction cup on my garmin sticks great while inside of my pickup, for a while. after some time and changes of temperature, the thing will come unstuck and the garmin will tumble off the dash and down to the floor or somewhere else in the truck. i can imagine that happening while on a bike. this poor old tom tom, trying real hard to stay hooked to the wire plugged into it, but losing the battle and ending up on the highway. short version of this is that i would not trust a suction cup to hold it.
Lawdawg
Dec 10, 2015 11:30 PM
UltraClassicElectraGlide
Jul 27, 2015 10:27 PM
amkaos
Oct 19, 2014 02:22 PM
PDDGM
Sep 16, 2011 08:01 PM
Boxer 6
Feb 1, 2010 08:18 PM
