metal in oil
Old Dec 22, 2010 | 12:32 PM
roadgliderick's Avatar
roadgliderick
Originally Posted by Port Dawg
I have just about 500 miles on my RK........was gonna change the oil out before the winter but figured I would just wait until the 1k mile check. With so few miles on the oil I wouldn't expect any etching etc even sitting for a few months. I do expect probably to see some metal flakes in there when I do change the fluids. Heck I remember seeing metal flakes in my car cartridge oil filter during an oil change I think what you are seeing is normal
hey dawg u know if u take your bike in for the 500 mile they change your oil for free. just thought u might wanna know.
Old Dec 22, 2010 | 04:03 PM
spider14043's Avatar
spider14043
Sorry man...you are so screwed. I'll bet you also have the seat that rubs on the gas tank. I hope you didn't get the bad compensator also.
Old Dec 22, 2010 | 04:08 PM
spider14043
And BTW...no such thing as a FREE oil change.
Old Dec 22, 2010 | 06:26 PM
roadgliderick
btw way on my 2 new bikes each 500 mile was free. and 1 more thing my compensator is a screamin eagle from the factory all 2011 touring bikes have the screamin eagle compensators. and i dont see how iam so screwed i do have a warranty.
Old Dec 22, 2010 | 06:34 PM
sifularson's Avatar
sifularson
You're right about the warranty. I'd only worry if the transmission started making noise or started shifting hard.
I'm a big believer in Redline Shockproof transmission oil. Have you thought about using it?
My 11 was difficult to get into neutral until I dropped the stock oil in favor of RL.
Last thing - I changed my trans oil at 500 and again at 3000. I drained it into a clean container and checked for metal. Very little found at 500 and none at 3000.
Good luck with your bike.
Steve
Old Dec 22, 2010 | 06:48 PM
roadgliderick
Steve
u know what sifu i cant find redline around here so i went to mobile 1 if i can find it i will buy it. and the tranny seems to b fine so i will wait and see what happens. listening to u and the others iam not gonna sweat it just ride it if goes it goes then i will up grade to a baker 7 speed. LOL thanks for your help i really appreciate your time and effort.
Rick
Old Dec 22, 2010 | 08:24 PM
Punjabi Rider's Avatar
Punjabi Rider
I had same issues on my 07 UC and ended up tranny and primary bearings went out at 17K .
Old Dec 23, 2010 | 11:44 AM
spider14043
Sarcasm. And, the "free" 500 mile service is priced into the cost of your purchase.
Old Jan 12, 2011 | 01:18 AM
WRKD4ITFLHX2008's Avatar
WRKD4ITFLHX2008
Originally Posted by harleyflhrs
there will always be little grey slug on yur trany plug. maybe little slivers of metal. normal ****.. but if u see huge amounts, then remove yur trany suite case cover. look in lower inside of case, if it is caked up there yur in trouble, mainshaft trouble. so just check that case. only 6 bolts,release clutch cable. it's insurance to look. not to alarm u..
While taking off my cluch release cover, I found some build up of shavings in the lower pockets also on my drain plug. My bikes is a 2008 touring , So my question what would cause the mainshaft/gears go bad, bad clutch adjustments or primary/drive line.
newt561
Oil Archive (no new posts)
Aug 16, 2017 12:18 PM
bennenrkc
Ironhead
Jun 18, 2014 10:32 AM
deadanal
Aug 29, 2012 10:19 PM
huntinjoe
May 21, 2007 12:19 PM
Inferno00
May 1, 2006 12:57 AM
