View Poll Results: A poll
21" Front Wheel
38.27%
18" Front Wheel
41.98%
Keep it a 16!
19.75%
Voters: 81. You may not vote on this poll
18" or 21" front wheel?
Old Oct 2, 2006 | 06:16 PM
  #31
BB06FLHX's Avatar
BB06FLHX
Default RE: 18" or 21" front wheel?
My vote is for a 21"
[IMG]local://upfiles/4515/5F44D9E977D347C3A9088FE863DFD195.jpg[/IMG]
Old Oct 2, 2006 | 10:04 PM
  #32
FireHog's Avatar
FireHog
I agree 21" looks the best. It fills out the front fender better.
Old Oct 6, 2006 | 06:11 AM
  #33
ZookHD's Avatar
ZookHD
ORIGINAL: Nails
ORIGINAL: GMONEY220
21" all the way bro.
For the 18" rear tire,get the Me 150!!!!!Do not get the 160 it has a history of stability problems and side drifting.Ask a hog pro tech,he'll tell you.Thats why metz came out with the 150 to match the front.Its a lil more expensive but its worth it without the headache and its a lil wider than the 160.I believe the problem was the front tire normally used was either a bias ply or radial and the 160 was a mismatch cant remember which,but i havent had any problems with my set up.Up grade to a six piston caliper brake and lose the right disc to show the wheel.
That is why I suggested the 19" front. You can run the 160/60-18 radial rear with the 120/70-19 radial front and have an oustanding handling bike. My buddy has this set-up and it handles like a BMW sport tourer.
BTW you have one of the best looking bagger's I've ever seen!
The problem with the 19" wheel it that it is made for a V-rod. You could do it, but you would have to change the hub! Go with the 21". Heres a pic of mine with PM Wrath wheels, a single side 13" rotor and a PM 6-piston rotor. ZOOK
[IMG]local://upfiles/13976/83F3D7B9A7B9426484EDEDD89ADF4918.jpg[/IMG]
[IMG]local://upfiles/13976/9E2E09D3A0B545A690E40B8DB829FDD4.jpg[/IMG]
Old Oct 11, 2006 | 09:52 PM
  #34
IceHeritage's Avatar
IceHeritage
Here is my 07 RG with 21 X 18
Old Oct 11, 2006 | 10:02 PM
  #35
CNC WHEEL GUY's Avatar
CNC WHEEL GUY
NICE!!!
Do you have pic from the other side? Would like to see that front spoked wheel from the other angle!
Denis
Old Oct 11, 2006 | 10:27 PM
  #36
IceHeritage
Here you go
Old Oct 11, 2006 | 10:48 PM
  #37
CNC WHEEL GUY
ORIGINAL: IceHeritage
Here you go
IceHeritage:
That thing ROCKS with the 21 spoker!!!
Where did you buy the wheel? Can I ask how much? That is an aftermarket wheel right?
Old Oct 11, 2006 | 11:24 PM
  #38
IceHeritage
Black Bike Wheels (www.blackbikewheels.com), $1700, Yes they are after Market, the shop that makes these wheels make a lot of wheels for Exile Cycles and Other Custom Builders. They are real good people to do business with
Old Oct 11, 2006 | 11:57 PM
  #39
Biggzed's Avatar
Biggzed
Ice - Thank you for posting that pic. That is the exact wheel size I will be putting on my Black RG as soon as it comes in. I have a little different idea for the spoke wheels, but the size was the issue for now. I was debating between 18 and 21 and this sealed it. You don't happen to have a pic from straight on the front you could post do you? I'm assuming the front tire is the 120/70/21. My only other concern is the huge fairing making the 21 front look too skinny. Sure does fill out the fender though.
Thanks
BZ
Old Oct 12, 2006 | 12:06 PM
  #40
IceHeritage
I don't have any saved on my System, i'll check my camera and if i find some i will post them
