Engine Color HELP
Old Jan 1, 2011 | 02:52 PM
DamifIknow's Avatar
DamifIknow
Originally Posted by DTTJGlide
How do you know this? The reason that the standards are cheaper is that MOCO eliminates the process of coating the engine.
My 06 Standard is also Powder coated silver. You can tell because the fins are not coated. Just like on a black engine.
Old Jan 1, 2011 | 02:53 PM
soft 02's Avatar
soft 02
I used an agresive solvent behind the rear cyl to prep for some epoxy and holy crap the paint wrinkled up and sure enough its a painted serface. I thought it was raw too. But that bieng said I dont know the paint code but it is definatlly painted on mine.
Old Jan 1, 2011 | 02:58 PM
DamifIknow's Avatar
DamifIknow
My 06 is also a Painted or powder coated finish. This is the color I'm trying to match. I going for the mono tone look vs. powder coating everything black.
Old Jan 1, 2011 | 02:59 PM
BadPiggy's Avatar
BadPiggy
The fin edges are run over a buffer wheel.
Naturally, it would be a different color.
Old Jan 1, 2011 | 03:03 PM
DTTJGlide's Avatar
DTTJGlide
Maybe the cases are coated, I know the cylinders aren't, sorry can't help anymore.
Old Jan 4, 2011 | 09:01 PM
Harleyboyddk's Avatar
Harleyboyddk
I think the silver motor parts on my FLHTI are powdercoaded as is the White Lightning. Go with the powdercompany you found that matches the factory silver. My White Lightning has silver cylinders and had raw aluminium rocker boxes I replaced with Chrome units. The silver cylinders and raw aluminium rocker boxes did not look similar.
Old Jan 4, 2011 | 09:32 PM
jimsuver's Avatar
jimsuver
That should read "chroming of the valve and side covers" the engine is coated.
You may have better luck with finding the color code from an 06 CVO silver engine. That Warlock Grey looks too dark, more like the 2011 CVO color on the engine.
MNtadpole
General Topics/Tech Tips
Feb 9, 2019 08:29 AM
UTnumber1
Powdercoat & Paint
Feb 11, 2013 10:59 AM
DamifIknow
Powdercoat & Paint
Jan 3, 2011 07:53 PM
jamesrgarner
Feb 2, 2009 07:50 AM
just_bob
Jan 6, 2007 10:14 AM
