Horn repair
With the switch on, check for voltage at the coil of the relay when you press the horn button. If there is no voltage there, then check the wires that are attached to the relay coil and trace them all the way back to the switch.
If there is voltage making it's way to the relay coil, then you need to verify that the relay is working. That Stebel pulls around 18 amps. As I said (emphatically) earlier, you should be using a 30 amp sealed automotive relay to power this horn. You should be able to hear a "click" when voltage is applied to the coil of the relay. That "click" is the relay contacts "making". If the relay is OK, then look for a fuse problem or some other connectivity problem back toward the battery (this horn should be wired directly to the battery via the relay...it should get it's voltage from NO OTHER SOURCE on your bike.
There should be a fuse between the relay and the battery. Or maybe the installer put the fuse between the relay and the horn. This is something you will need to determine. See if you can find this fuse. You should have a 25 amp fuse in-line preferably between the battery and the relay, anything less has the propensity to blow due to intermittent inrush current....especially when the horn is operated with only the switch on and the motor not running. The horn will try to pull the wattage it needs, so if your bike is not running, and the battery voltage is below normal, it will pull more amps to make the power it needs....so sometimes a marginally rated fuse might blow in this condition....but not every time...this is just a possibility worth noting. You can get a weather-proof fuse holder that takes the larger blade-type automotive fuses from any of the auto parts stores. That's what I use.
Just keep chugging...you will eventually find the problem. Keep the faith and don't lose patience. This kind of thing is a learning experience for anyone that has ever messed with it, and you will come away with knowledge about your bike that you did not have before you started working this issue.
And knowledge is a good thing!
