Crank TIR
Old Jan 5, 2011 | 05:56 PM
cgunvil's Avatar
cgunvil
Unhappy Crank TIR
I got 07 S.G. with with 30k miles, Doing a motor build on it found out crank has .009 run out.
Is that normal issue with the TC or is it just my luck ?
Old Jan 5, 2011 | 07:01 PM
93 outlaw's Avatar
93 outlaw
4th Gear
I only have 2800 miles and I checked mine when I installed my Fuel Moto 107" kit and it was .003
Old Jan 6, 2011 | 02:57 AM
Watch Guy's Avatar
Watch Guy
Default What exactly is run out?
I see it mentioned a lot here.
Old Jan 6, 2011 | 06:55 AM
cgunvil's Avatar
cgunvil
Watch Guy
Run out is when the Crank shaft is held on bearing areas and it is rotated with an indicator on the outer most point (by the cam gear)in one rev. the total amount of .000 it is not straight. Hope that helps ?
Old Jan 7, 2011 | 03:29 AM
Watch Guy's Avatar
Watch Guy
Default Thanks but doesn't help at all
Originally Posted by cgunvil
Watch Guy
might as well be speaking in Greek.
Old Jan 7, 2011 | 08:14 AM
cochon's Avatar
cochon
If the crank is bent, the center of the shaft does not rotate in a fixed location. Rather, as it rotates, it moves in an arc around a center point. If the center of your shaft had a pencil mounted perfectly to it, and the shaft was not bent it would leave a pencil point on a piece of paper, if the shaft was bent, as it rotated, the pencil would draw a circle on that paper. The numbers that we are using here are very small and the average guy can't see .009 very well. Because of this, we use a measuring device called a dial indicator. So, the term that you hear is TIR, Total Indicator Runout , the amount that your crankshaft is bent. .009 doesn't sound like much until you realize that at 4000 rpm your crank is turning a revolution 4000 times every minute, so multiply .009 times 4000 to see total movement of your shaft. It's alot.
Old Jan 8, 2011 | 04:06 AM
Watch Guy's Avatar
Watch Guy
Default Ok, I get it now
it just means the crank rotates out of round. Seems like an issue that would never come up unless the main bearing kept wearing out or excessive vibration.
elie2000elie
EVO
19
Mar 24, 2018 09:10 PM
merdahl
2014-2024 Touring Models
Sep 10, 2017 09:07 AM
Nan's_Performance
Apr 6, 2014 05:34 PM
Nick
Exhaust System Topics
20
Jul 17, 2012 09:12 AM
jacknthebox
Dec 29, 2010 11:21 PM
