Does removing BAFFLE WRAP affect back pressure or just volume?
But consider this... The torque you sacrifice by reducing the back pressure slightly will probably be offset, psychologically anyway, by the louder pipes.
Ever notice that louder feels faster even if it really isn't?
A straight pipe, with no baffle or wrap results in the least amount of back pressure leaving only the pipe itself to limit the amount of air flow.
The loudest pipes you have probably ever heard, were likely pipes with no baffle or baffle packing.
Often times, pipes that originally had baffling, over time, burn the baffling right out of them. They will sound louder and provide less back pressure if so. Some elect to buy new baffling wrap and re-wrap the baffles to either quiet the pipes back down or to regain some lost back pressure.
My Vance N Hines straight pipes on ym Roadstar came with nobaffle wrap, however, the baffle itself was a long 22". I took the baffle out and cut it down 10" to 12" long. The result, was a bit louder and less back pressure. Since i liked the new sound and there was little seat of the pants difference in performance, I took them out again and cut another 6"s off to 6" long.
I lost some back pressure, but not enough to make a big difference...but I gained a good bit of noticeable deeper tone and loudness. I never did feel the need to rejet the carb, again, it didn't make that big of a difference.
Now if you have a long 22" baffle AND baffling wrap and yank it all out at once and just run a straight pipe, you might just notice a large lack of back pressure and performance.
In your case, I wouldn't think removing the wrap and shortening the baffle would make a ton of difference with a slip on muffler. You should gain some sound tho.
If you're going to yank the baffle, try running it without the baffle and see what you think. Shouldn't be harmful for a short term setup, just not ideal performance.
If you want a real nice sound, save up for a full true dual exhuast sytem.
Phew......hopefully some of all that made sense....lol
