Right muffler turning yellow
Old Jan 15, 2011 | 12:12 PM
SpiderPig's Avatar
SpiderPig
Default Right muffler turning yellow
Anyone running a stock 2010 or 2011 and have the right muffler turning color from the heat? I now have a 103 in a Limited which after 6,000 miles the front of right muffler is a nice shade of amber. My question is will HD cover this as the bike is totally stock? Even being that they are running lean with the cat, it shouldn't be to the point of the pipes turning color. Has anyone addressed this with their dealer and what was the outcome? I would think they would do something with the ECM and replace the muffler? Any advice before I head to the dealer would be helpful.
I also have the primary making a huge "CLUNK" upon start up. I have read here where some have had theirs replaced with the S.E. unit and they paid the difference in the cost of the part (S.E. vs stock).
Old Jan 15, 2011 | 12:19 PM
WRKD4ITFLHX2008's Avatar
WRKD4ITFLHX2008
tighten up your slip-on possible leaking at pipe and slip-on point , two possiable stator going bad, or tranny ckeck your oil in primary/tranny your oil can tell you a lot.
Old Jan 15, 2011 | 12:24 PM
hojones's Avatar
hojones
I'd take it back in for warrenty. If you are still running stock exhausts they shouldn't be turning. Usually thats a sign of running too lean. They can hook it up and tell. May just need some tuning and the muffler should be taken care of.
Old Jan 15, 2011 | 12:36 PM
leohd's Avatar
leohd
be prepared to hear THAT'S NORMAL
Old Jan 15, 2011 | 12:41 PM
SpiderPig's Avatar
SpiderPig
"That's normal" BS is not going to fly. Bike is stock so they should have no excuses. This is why I posted, I am curious if anyone else has had a similar issue and what was done to correct it.
Old Jan 15, 2011 | 01:56 PM
Raptor1956's Avatar
Raptor1956
Just asking. Was told by an old timer if it turns blue it is too lean if it turns yellow it is too rich. Is that true?
Old Jan 15, 2011 | 01:58 PM
FX4's Avatar
FX4
Well I don't know if its true, but my bike runs on the rich side and my right inlet is yellow.
Old Jan 15, 2011 | 02:11 PM
RK14SGS's Avatar
RK14SGS
Blue is lean. Yellow is rich. Odd because the bike is stock. Bang at start up is compensator, not rotor. Stand firm and get the SE comp... the muffler is odd, if its rich, a replacement should turn too over time..
Old Jan 15, 2011 | 02:51 PM
fabrik8r's Avatar
fabrik8r
That shade tree rule of thumb may be a little off base. Extreme temperatures of the exhaust gasses cause the exhaust system to heat up, as temperatures near or exceed the critical temperature of the base metal, the surface color will begin to change from yellow to gold to blue to purple. The leaner the tune, the hotter the exhaust gasses, the darker the blue color. It has been my experience that even a stoich tune, neither rich nor lean, will still cause bluing in “standard” single wall exhaust tubing and mufflers. Maybe if the color never gets worse than slightly yellow or gold, that could indicate that AFR is a little rich, or cooler, so the exhaust gases are not getting hot enough to cause full on bluing. Still not a very good indicator of tune condition, because the countless different chemical compositions of metals by different manufacturers all have slightly different critical temperatures. That being said, a stock bike under warranty with bluing should be taken care of by the dealership.
Old Jan 15, 2011 | 03:04 PM
sonar_chris's Avatar
sonar_chris
Moco isn't going to warranty the chrome color on your muffler. None of the exhaust manufactures do. They will consider it a cosmetic issue. But, if your dealer is a decent one, they will fix it for you under warranty.
