My First Fiberglass Project
Old Jan 16, 2011 | 07:46 PM
SunCruise's Avatar
SunCruise
Default My First Fiberglass Project
I bought a really nice sprung solo rail seat for my '09 FLHRC and found I didn't like seeing all that was under the seat especially with the newer frame being wider starting at the front of the seat. I Looked at the "police" frame fairing but fit was poor not to mention the big hole in it for the air shock. So I decided to try this:
1) Using Shrink Wrap I snugged it to the frame using a small plumbers torch.
2) Continued to cover as much of the bike as needed. No heat just tape
3) Laid out fiberlass cloth and brushed on the resin. 3 layers of course and 2 layers of fine cloth
4) Release was easy and did a rough trim with a cut wheel (be careful)
5) Fine point marker and careful trimming using the side of the cut wheel like a grinder and fit it close to allow fitment of the side covers.
6) A little hand sanding with course then medium sandpaper and a coat of sandable primer.
The finished black cover will be matt or flat or krinkle type finish so the smoothness doesn't have to be perfect like for a glossy reflection.
Attached Thumbnails My First Fiberglass Project-wrap-2.jpg   My First Fiberglass Project-fiber-2.jpg   My First Fiberglass Project-release.jpg   My First Fiberglass Project-trim-2.jpg   My First Fiberglass Project-primer-2.jpg
Old Jan 16, 2011 | 07:51 PM
pittz5's Avatar
pittz5
damn nice work! id like to see it with spring seat.
Old Jan 16, 2011 | 08:21 PM
jimsuver's Avatar
jimsuver
Man! That looks great!
Old Jan 16, 2011 | 08:56 PM
Ron "Gunner" Retzlaff's Avatar
Nice work SunCruise. I would like to see that with the solo seat on it as well!
Old Jan 17, 2011 | 06:34 PM
SunCruise's Avatar
SunCruise
Default Solo Seat
Thanks !! This is an earlier pic...before fab of the frame fairing. I plan on a little more trimming; perhaps where the front corners roll over the frame. As it turns out they are not needed to hold it in place and I think they make the front look too square. Today I picked up some 3/4 wide by 1/4 thick adheasive foam tape for the underside that will compress and ride the frame. SC
Old Jan 17, 2011 | 09:13 PM
badknees's Avatar
badknees
Nice job. Looks good.
Old Mar 21, 2011 | 06:02 PM
SunCruise's Avatar
SunCruise
Smile Update !!
7) Ok the flat black was to obvious...found a slightly textured "metalic look" paint but came out more silver speckle than black. Could not find matte black, thought maybe satin (trying to match the piece between seat and tank) then I saw semi-flat ? I've heard of semi-gloss but semi-flat ? hmmm. Just enough shine to show some imperfections in my sanding etc. It almost looks like leather and blends so well with the overall look. I like it.
You may also notice shims above the crash bar... they give the seat rail a little more clearance above the new hard bags.
Attached Thumbnails My First Fiberglass Project-ff3.jpg   My First Fiberglass Project-ff4.jpg   My First Fiberglass Project-classy2.jpg   My First Fiberglass Project-ff1b.jpg
Last edited by SunCruise; Mar 21, 2011 at 07:08 PM. Reason: the last pic was upside down :/
Old Mar 21, 2011 | 06:15 PM
grbrown's Avatar
grbrown
You say this is your first fibreglass project, but have done a remarkably good job. Well done.
Old Mar 21, 2011 | 07:41 PM
mannya4's Avatar
mannya4
Great job, looks good!
Old Mar 22, 2011 | 02:25 AM
emwolb's Avatar
emwolb
man i've been glassing up stuff for my hot rods and bikes for years, and your work makes me look like an amateur. you did some really great work there, it looks sharp.
