Port and polish
Thanks for you ideas and suggestions
They did a huge write up about these guys and the scottsman head job in HOTBIKE a couple years back. If you can look up back issues of Hot Bike its Volume 40 No. 11 2008. It explains everything you need to know about airflow, air volume, etc.... Check em out, when I can afford it they are whom I am going with
Gary
I made that mistake last year, and when I got the bike home, it made GREAT numbers, but ran rough and HOT, had all kinds of hot-start issues,
the ccp was 225/230 front/rear respectively, and I had detonation even after the timing was retarded.
The bike was much better with stock heads, as the 255s can't handle the compression above 9.5-9.7 CR, and before the head work, the bike just flew!!
(Worst money I ever spent, as I was only chasing numbers!)
Anyway...
If you're going with headwork, change your cams, and I hear the Wood cams are pretty popular: TW5-6, TW6-6, TW-7H, TW-555, etc.
