Another tensioner post.
Old Jan 19, 2011 | 04:52 PM
djl's Avatar
djl
Originally Posted by grandpatim
I want to do it myself. I did all my wrenching on my Goldwing which was something I took pride in. But I don't really want to buy tools that I will use once. Do I have to have the inner bearing puller to do the job myself? Or does taking the assembly to the dealer do away with needing any of the specialty tools? I just figured even if they weren't worn that bad to go ahead and get it over with.
You can rent a universal blind hole puller from most of the auto parts places like Auto Zone, Advanced Auto, etc. or the tool rental places. It looks like this:
http://www.harborfreight.com/blind-h...ler-95987.html
If you go the hybrid route just have the dealer order the parts and when the parts come in take them your assembled OEM cam plate and let them make the change over. Rent the inner baering puller and R/R the inner bearings. Line up the timing marks on the ouer drive sprockets, install the oil pump, stab the assembled cam plate, align/install the oil pump and your done, almost. If you were to go the '07 OEM route, you can R/R the cam plate in your garage with no special tools but you still need the puller for the inner cam bearings and you would need new N style conversion cams; stockers won't work with the '07 OEM cam plate and this would add to your cost. At 34K miles, I would install new lifters as well.
I don't recall what you had planned to do about pushrods; changing to adjustables or retaining stock? If retaining stock you will need to raise (I find it less hassle to remove) the fuel tank, remove rocker box covers, loosen rocker arm supports and pull pushrods from the top; reverse process to close. If adjustables, clip the stock pushrods with a large bolt cutter and install the adjustables from the bottom. The trade off is more money/less work with adustables but you do have to adjust them. Save money and no adjusting with stock pushrods but more work; your call.
You can do it but you need the service manual for your model.
Old Jan 19, 2011 | 05:17 PM
DTTJGlide's Avatar
DTTJGlide
On a 2001 fuel injected bike you will also need a special outer cam drive gear if you want to use the new roller style chain on the outer drive.Andrews makes one & it runs about $60, you run the original cam chain as that's what you'll be running on the inner unless you decide to change cams. I did the SE kit install this fall & I went with the new gear & chain set up, mostly because I had 68K on the bike before I did the upgrade. I went the SE set up since I already had Crane cams in the bike. It's your call on the lifters, both my cams & lifters looked great & were quiet so I didn't see any reason for a change, the lifters are straight out of a LT-1 small block chevy & they last a lot longer than that in a V-8. HD had trouble with the EVO lifters, but I haven't heard of much problem with the TCs, I'd say if they look good & haven't been noisy to leave them alone, just make sure to mark them so they run in the same direction on the same cam lobes as before. As djl said I think the SE kit is worth it for the upgraded oil pump, 15# oil pressure instead of 3-5# at idle with the old pump. I know I wouldn't go with gear drive set up without upgrading the oil pump, that makes the price difference considerably more. Good luck with whatever you decide.
Old Jan 19, 2011 | 06:08 PM
ElectraDave's Avatar
ElectraDave
Hmmm....now I'm rethinking my planned gear drive cam changeover. Seems the improved oil pump that comes with the HD kit is a very big bonus IMO.
Old Jan 19, 2011 | 06:21 PM
slyder's Avatar
slyder
Get a Herko Pro Kit from www.flyingwperformance.com John includes absolutely everything you will need to complete the job. He assembles these kits with mostly HD parts. Everything is labeled and packaged nicely. Makes it really easy on a guy. I just used one this past weekend and recommend the hell out of him.
Old Jan 19, 2011 | 07:33 PM
grandpatim's Avatar
grandpatim
If I do it myself then all I need is a blind bearing puller, a hydraulic press and some bolt cutters?
Old Jan 19, 2011 | 08:22 PM
rdam's Avatar
rdam
Originally Posted by djl
The banter that the parasitic power drain of the chain drives is greater than the parasitic power drain of gear drives has never been proven. Both require HP to drive them and I would bet a six pack that the parasitic power drain is near the same. Furthermore, if there is a difference, it won't win/lose a race or register on the "butt dyno".
I'm no mechanic, but I'm pretty sure the friction of gear on chain with spring loaded friction producing tensioners pressed against the chain, are going to "drain" more HP than direct gear to gear contact.
The gear drive manufacturers advertise a 5 hp increase based on the gear drives alone. I think that's a pretty good estimate. I went to a very mild 21G cam when I went to gears and noticed a substantial increase on the "butt" dyno. With the very mild cam, some of that has to be attributed to the gear to gear reduction in friction IMO.
Old Jan 22, 2011 | 09:58 AM
Stiggy's Avatar
Stiggy
Good Advice both ways today!
Just finished my gear drive conversion '00 FLTRSEI, 82,000 miles, and decided on the gear drives because I needed new cams, Andrews 26G, more than I needed a new oil pump. I also ride 20,000 miles a year here in NC so I never wanted to worry about tensioners again. But I have no issues whatsoever with a lower milage bike with still good cams in choosing the hydraulic set up. It's a vast improvement on what I took out of mine.
I had no lash issues so the kit parts fit and it's as quiet as the chains were. I bought the bearing tools on EBAY and sold them again this weekend. Only help I needed was the hydraulic press.
With an '01 either should be a quick install and will last.
Old Jan 22, 2011 | 11:35 AM
djl's Avatar
djl
What else would you expect the gear drive manufacturers to say? Of course, there is no data to support the claim but anyone that thinks gears don't require HP to drive them doesn't understand mechanics. Changing cams and drive system at the same time and attributing part of the "butt" dyno increase tothe gear drives is purely subjective and a misleading statement; can't be done.
In any event, parasitic loss from either system should not be a consideration for selecting one over the other. When one starts using the red herring HP gain/loss argument for gear drives, that means they just want to go with gears and that's fine; just say so.
Old Jan 22, 2011 | 02:57 PM
grbrown's Avatar
grbrown
Some of the best for and agin debate here, on the gears versus hydraulic route. I have to say the hydraulic route is the one I would pick for my Dyna, along with a set of mild cams. Doesn't do a high mileage (2nd/3rd bike), so time yet to make a final decision!
Old Jan 22, 2011 | 05:25 PM
karbar99's Avatar
karbar99
Originally Posted by tall jerry
do it. went to my local hd dealer today to price out the exactly same thing. winter speical 825.00 complete,free pickup & delivery within 20 mi of dealership. there is still 3 inches of snow on the ground.
Besides labor, what are you geting besides the new Hydraulic Cam Chain Tensioner Plate Upgrade Kit & Gasket kit? Inner Bearings, Lifters, Adj Pushrods (not that they're needed)??
Baggrmark
Sep 4, 2021 04:59 AM
gwnewg
Apr 22, 2018 09:49 AM
suey 1958
Feb 15, 2012 11:27 PM
cubalz
Oct 11, 2011 02:20 PM
hambone51
Exhaust System Topics
Mar 17, 2008 02:13 PM
