adjusting pushrods
Old Jan 22, 2011 | 05:12 PM
slyder's Avatar
slyder
Default adjusting pushrods
I installed new cams last weekend and finally got my exhaust on today. After I got my map installed i cranked it up and noticed alot of lifter noise. I have the rear cylinder at TDC right now and can move the pushrods freely and there is a little movement. Question is should I collapse the pushrods completely and start the adjustment process over or just tighten them up just a half turn or so? The lifters were brand new so there was no bleeding them down originally. These are SE tapered rods so it was originally 2.5 turns.
Old Jan 22, 2011 | 05:34 PM
Mr. Wannabe's Avatar
Mr. Wannabe
Well ****, if this were about solid lifters I could help. You have to collapse the lifter per manufacturer spec BUT they gotta bleed down between adjustments. I hate hydro lifters for this reason. It's so much easier with solid lifters, noisier, but easier.
Old Jan 22, 2011 | 05:38 PM
1931jamesw's Avatar
1931jamesw
What cams are you running? If it were me I'd re-adjust for the sake of not wondering and worrying. You can go a little further out than 2.5 turns and get rid of some noise.
Old Jan 22, 2011 | 05:43 PM
Stiggy's Avatar
Stiggy
If you didn't soak the lifters in oil the night before, you'll need to re-adjust.
Old Jan 22, 2011 | 07:59 PM
slyder's Avatar
slyder
so back them off and start over? Im running Andrews 21Ns
Old Jan 22, 2011 | 08:16 PM
Teardrop's Avatar
Teardrop
For peace of mind I would start over.
Old Jan 22, 2011 | 08:19 PM
Stiggy's Avatar
Stiggy
Sure, just loose to start and re-adjust. I'm sure they'll be fine.
Old Jan 23, 2011 | 03:31 PM
slyder's Avatar
slyder
Thats all it needed. Backed em all off and started over now she purrs like a kittin. Nice and quiet too. I almost killed myself in the garage letting it run and listening to the new Pro Pipe. Had to open the door and let some -10 degree air in.
Little Mike
Engine Mechanical Topics
17
Dec 3, 2016 08:29 PM
Scrmnvtwins
Jul 10, 2015 06:10 AM
HighonHarley
Jan 29, 2015 07:23 PM
73shovel rider
Mar 16, 2014 06:37 PM
SDVmnt
Jul 2, 2010 10:19 PM
