Road King Solo Seat
Old Jan 25, 2011 | 11:29 AM
Canadian Castaway's Avatar
Canadian Castaway
Post Road King Solo Seat
I am looking to purchase a custom RK Solo Seat, my question is what mounting brackets are required to mount the Solo Seat, I presently own two 2up seats, the original and a Mustang any suggestions would be apprciated.
Candian Castaway
Old Jan 25, 2011 | 11:40 AM
jvvjvv's Avatar
jvvjvv
What year bike??..........09 up the Mustang seat just bolts on. The Corbin comes with front and rear brackets and bolts on. "pretty" sure all the otther do also.
I have a new Mustang super solo listed in the claasified forum if you are intrested.
Old Jan 25, 2011 | 11:41 AM
Bait56's Avatar
Bait56
Mine is a HD Brawler seat. Take one bolt off, pull off the seat, push in the other to seat the lip, one bolt back.
Old Jan 25, 2011 | 11:58 AM
Harleypingman's Avatar
Harleypingman
If you have a 2003 RK, under your two-up seat should be two-threaded studs; most solo seats use those threaded studs with nuts to secure the rear of the seat and the front is secured with a slide in tab that fits in the frame cut-out.
Carl
Old Jan 25, 2011 | 03:37 PM
Canadian Castaway
Default Solo Seat
Hey Carl Thanks,
I wasn't sure if those two bolts were used for the Solo seat, but that is what mine has, because I bought the bike used I thought they were in place for the Mustang seat the original owner put on it. I'm gonna look at a Solo Seat tomorrow, so I'll look for the brackets that should be in place for that seat.
Thanks All
Canadian Castaway
Old Jan 25, 2011 | 03:49 PM
reh13's Avatar
reh13
Some solo seats (corbin, danny gray, and I believe c&c...etc) use a T-bracket that bolt to the two studs you're refering to, and extends back a few inched. The seat itself then covers the two studs.
Old Jan 26, 2011 | 07:31 AM
RoadKing06's Avatar
RoadKing06
I'm running the Sundowner Solo and it requires an additional bracket the bolts to the bottom of the seat then to the 2 bolts mentioned in the above post. The bolts have a nut towards the bottom then a notch where you would add the Sundowner pillon for your passenger. The pillon slips in and secures in the back at the rear mount point for your standard Harley 2-up seats.
Old Jan 26, 2011 | 07:47 AM
ericl's Avatar
ericl
Danny Gray uses a T-bracket, the bracket anchors to the two studs mentioned earlier, and has a single threaded post where you secure the tab of the solo seat to, simple on and off.
Old Jan 26, 2011 | 08:14 AM
Cornhusker's Avatar
Cornhusker
That's the set up on my Danny Gray Speed Cradle solo.
sbeast
Nov 9, 2015 10:38 PM
CSS_FXD
Jun 22, 2014 03:19 PM
mjaw
Sep 1, 2012 02:31 PM
ramirolozano
General Topics/Tech Tips
Jan 18, 2009 09:45 AM
Matt115
May 27, 2006 12:05 PM
