If I'm just interested in an enclosed trailer to fit my Road King what do you guys think of this one? Seems the price is right. I probably wouldn't use it more than a couple of times a year. I would be pulling it behind a Jeep Liberty.
It looks a lot like the Legend I looked at today. I'm ready to pull the trigger except for one thing my friend said that has been bugging me. He's got a 6x12v-nose and says he can't put his bike all the way to the front as it makes it too tongue heavy.
It's not a problem as he has the room to move it back. With the 5x8 I won't have that luxury. Maybe it's not an issue with the 5x8.
Rick
You have to watch the weight distribution in a trailer. Usually 60/40 over the axle. With the 60 being in front of the axle. When I first got mine, I pulled my bike all the way forward, and eventually had to reposition the chock further to the rear. You don't want too much weight on the tongue. I have a 5X10 and have no problem. You better make sure you can fit your bike in a 5X8. I know my Road King would be very tight if it fit at all. You'd be better with a 5X10.
I checked out the trailer yesterday and the bike will fit in the 5x8 v-nose with 8" to spare. I need an additional 4" for the chock I'm looking at so I only have 4" left. It doesn't leave much wiggle room if I'm loaded to far forward.
In all my trailer research I don't recall coming across any 5X10's. It seemed like the next step was 6x10.
How far back did you have to move your bike?
Rick
I have a Haulmark TS 5X10 Cargo trailer. It's not a V-nose. I have my RK just a little rear of centered in the trailer. Have about a foot and half in front for cargo, and about a foot in rear. Side door for easy access. Total cost was about $2300. with alum wheels.
The interior shot was before I moved the chock back and put the spare on the rear wall.
Looks good, I'm just trying to keep the total weight down and moving to a 5x10 steel frame adds another 300lbs. I might be worrying about nothing. Maybe I'll be alright (I hope).
Scrolled down to the bottom of the link you posted and the figure was in the calculation box and I ASSuMEd that was the price of the trailer. Didn't really look close enough I guess. I was able to delete that figure when I just now went back so I guess that was not the price of the trailer.
As I said before, I have a 5 x 8 v-nose. And an 08 Ultra. I put a "condor" type chock in mine. A friend and me made it out of steel (the chock) and it's a heavy sucker. I can put the spare trailer tire in front of the chock with room to spare. The rear of my bike is about 3 - 4 inches from the door when closed. Balance is good. I pull it with either a GMC Envoy 6cyl. or GMC Sonoma with the 4.3 V6. The pickup does a little better pulling it seems like. With either vehicle it pulls O.K., but you do know it is back there when you hit a hill. Stopping hasn't been a problem so far. I have pulled this set up several miles with both vehicles. I would like a little bigger trailer if I had it to do over again, but I wouldn't want to pull it with the vehicles I have now. I think the pickup could handle it O.K. but a bigger tow vehicle would be better IMO. (I think I would be allright with a bigger trailer with my current vehicles if I had a lighter trailer like a Featherlite.)
Trailers are like storage space. The bigger the trailer, the more crap/weight you will tend to take along.
Look at the snowmobile trailers with the front doors for ride on, ride off, advantage.
Just used one similar to described to haul my street bob down to a shop in the Portland area for some work. Towed well, the only down side to this configuration is the deck height is built quite high to allow for clearance when towing snowmobiles off road in the winter so the top of the trailer was significantly higher than my Suburban. Result was increased wind drag and impact to the mileage even though the front of the trailer is V shaped. This profile did help on the way home though, had a tail wind and the mileage picked up considerably (used half as much gas heading home).
As to the discussion related to torsion axles, I will be getting those for sure as they help to keep the deck height lower. Have used / maintained several trailers with them over the years and haven't had any problems.
All these trailers have different specs. I checked the specs on your trailer at the Classic web site and sure enough, you have an extra 12" inside and it all looks like it's behind the axle compared to the one I'm looking at. That would definitely help with the balance. It appears to be a nicer trailer than I'm looking at. I'm trying to get as light as possible and as cheap as possible (aren't we all?).
I guess the next thing I'm wondering is if I'm ordering the trailer if I could have the axle moved forward 6". I think I'll email the manufacturer and find out. If I can this trailer would work out pretty well as it only weighs 770lbs.
If we didn't have the snow on the roads I would just ride the bike over and run into one of their stock trailers, but that won't be possible in MI for a while.
