Low End Torque Cam
Old Jan 29, 2011 | 08:20 AM
BlackBastard's Avatar
BlackBastard
Originally Posted by Tripleshot
I just put in an andrews 48h and it is great for low and mid range tq
I agree in a stock 96" the way to go since you may not do headwork or use a thinner head gasket to raise the compression. Don't over cam a stocker!!!
Old Jan 29, 2011 | 08:36 AM
imrotton2's Avatar
imrotton2
Originally Posted by gregory
Is anyone familar with S&S's #551 or 570 easy start cams? I decided to go with their 106" kit and real like the idea of not having to machine away cooling fins for compression releases. Mainly interested in low end torque for my 2009 FLHR.
greg
the 570's will do you good... i dont have the easy starts , (ive got gear drive) on my 103", tq is in the 120 range @3700rpms
Old Jan 30, 2011 | 07:39 AM
gregsdart's Avatar
gregsdart
Default Cam comparo
greg
If low end torque means idle to 3,000 rpm, it is very hard to beat the 255 cams. I will go out on a limn and say near impossible for low end roll on.
Before you toss the 255 option out, take a good look at direct comparisons between the 255 and what you want. Also go out and ride around and take note of where you shift most times, and what is your desired range for cruising around. If you don't have a tach, someone here can do the math for you if you come back with a mph and which gear you shifted out of. I was surprised at how low the rpm was that I rode at after getting a bike with a tach.
Old Jan 30, 2011 | 09:28 AM
GEORGEW's Avatar
GEORGEW
I could not agree More with the above statement,,
I have been looking at Cams for a over a year, To install in my 09 Root Beer Ultra,, Been watching my Tach and would like to add this,, Watch Your TACH IN 4TH ,5TH & 6TH GEAR on a all day Sunday Ride with your friends you will find out how LITTLE you are even close to REDLINE,,,I have decided to go with the 255's because I want POWER I CAN USE 90/95 Percent of the Time. Because ITS A BAGGER NOT A RACE BIKE,,,,
Old Jan 30, 2011 | 09:58 AM
fripple's Avatar
fripple
went with the SE-204 in my 96". Made a huge difference when riding 2 up. 91hp and 109tq....Picked the cam up used and I had zero complaints....
Old Jan 30, 2011 | 10:19 AM
Ridewva's Avatar
Ridewva
To be honest I don't know much about cams but this thread has peaked my interest. The SE-255 cams appear to offer enough of a bump in torque for me, and most importantly down low where I want it. In other forum discussions I've read, cams with (more?) overlap enable the engine to run a little cooler. Do the 255's have more overlap than the stock and help in cooling as well?
Old Jan 30, 2011 | 10:49 AM
sporacer's Avatar
sporacer
T-man 555 cams or the woods tw-555 are showing great numbers and they dont fall off like the 255's do.
Old Jan 30, 2011 | 01:52 PM
iclick's Avatar
iclick
I monitor both oil and head temperatures on my bike and don't notice any difference in cooling between the stock cams and the 255's using the same lean AFR's for both. This bike runs relatively cool compared to most, even others equipped with an oil cooler. I run stock AFR's in the cruise-range for mileage with the option to switch the PCV to a richer map if needed, but I rarely need to use it.
Old Apr 29, 2013 | 12:48 PM
CoachJR's Avatar
CoachJR
Can you simply install cams and get the desired results, or do other mods need to be made?
I have a 2013 RK with stage one AC, V&H True Duals, and V&H Twin Slash Ovals. Will the 255s alone add more low end torque to this particular set up? If that's the gain, what's the loss? What do you compromise to get this low end torque?
Old Apr 29, 2013 | 01:04 PM
Pondskipper's Avatar
Pondskipper
222,s seem to pull the torque in nicely but the 555 gives a more balanced spread with hp.
strange1
Exhaust System Topics
Dec 9, 2018 09:19 PM
Cascade
Dec 14, 2014 07:47 PM
Iron lHorse
Dec 13, 2013 02:13 AM
Sgt7212
Oct 22, 2012 07:45 PM
RoadieRider
Jul 28, 2007 08:50 AM
