2010 models high oil consumption?
Old Jan 28, 2011 | 12:46 AM
oct1949's Avatar
oct1949
Default 2010 models high oil consumption?
Update in post # 35,,,,,,Friend bought last summer new Ultra (Still 100% stock), says she's using QT per K. Still under 10k on her.
He say its a common Valve guide issue on the 10's, I told him I've not heard of any problems.
Anyone heard or have a problem with the 2010 motor with oil usage.?
Old Jan 28, 2011 | 01:09 AM
2black1s's Avatar
2black1s
I don't have a 2010 so I can't comment from that perspective.
But oil consumption through the valve guides can sometimes (if it's bad enough) be diagnosed by evidence of smoke at initial start-up after sitting for a while.
Old Jan 28, 2011 | 02:14 AM
leohd's Avatar
leohd
probably isn't broken in yet, have him race the **** out of it so everything seats right, if not he should have warranty left
Old Jan 28, 2011 | 02:40 AM
Chuck1's Avatar
Chuck1
A quart/thousand miles is not common. I have a 10 plus had others and never used that much. Late models never used any for me, older bikes used a little bit but never that much.
I'd be talking to dealer.
Old Jan 28, 2011 | 04:32 AM
mainshaft's Avatar
mainshaft
I don't have a 2010 but like Chuck stated, 1QT every 1K seems to be tooooo much. Does it smoke on start up or does he notice oil cpming out of the pipes while he is riding?
Old Jan 28, 2011 | 04:34 AM
dc1450's Avatar
dc1450
Sounds like defective valve seals, my '05 had them. It never used oil but at about 25K it gulped two quarts on a two thousand mile trip. I told the service dept. about it and they changed out the seals on warranty. 67K now and it still doesn't use oil between the 5K mile service intervals.
Old Jan 28, 2011 | 04:40 AM
JayStronghawk's Avatar
JayStronghawk
If no signs of leakage, valves seals looks like a great place to start .. 1 QT in 1K, Even my old ironhead didn't use that, unless ready for a rebuild..
Old Jan 28, 2011 | 05:32 AM
missile's Avatar
missile
I normally had to add 2 - 3 quarts every 5000 miles. Finally from 15000-20000 miles it hasn't used a drop. I never seen my bike smoke and none of my buddies could see it smoke.
Old Jan 28, 2011 | 05:47 AM
1931jamesw's Avatar
1931jamesw
That's entirely too much oil useage. Hell that's almost measurable by miles per gallon. He needs to be up his dealers *** about that and demand it gets taken care of and the sooner the better. Spring is just around the corner.
Old Jan 28, 2011 | 06:02 AM
Olde Skool's Avatar
Olde Skool
Don't have a 2010. My 2007 will not use a drop UNLESS I am blowing down the super slab at 75-85 MPH. Then it used about a half a quart on my personal best mileage (782 miles) for one day.
Spend a lot of time at 75+ MPH ?
