Primary oil level
Old Jan 29, 2011 | 09:20 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Originally Posted by Faast Ed
You'd be surprised how much stays. 7 oz isn't much. There are a whole bunch of clutch plates in there and every one of them coated with oil.
If the cover was off and the plates were pulled out or replaced, or had a long time to drip dry, it will take near that 45 oz to reach your visual checkpoint.
My visual check point is the clutch spring. I like to see the bottom edge of it barely submerged.
You may be right, I did the SE Comp change and had everything out of the primary. I poured one quart of ATF in, added some from the second quart until it just touched the bottom of the clutch pack. I really didn't look to see how much I used from that second quart but I will tomorrow for the hell of it.
Old Jan 29, 2011 | 09:48 PM
Faast Ed's Avatar
Faast Ed
Call me ****, but I always use a cooking type measuring container and measure what I pour in from the second quart. More of a curiosity thing than anything else.
Bottom of the clutch spring is my final determining point.
Old Jan 30, 2011 | 05:44 AM
Olde Skool's Avatar
Olde Skool
It may be over kill but I also change the primary and transmission at every 2500 mile oil change. Nothing but the best for my baby! Oil is cheap insurance...
Old Mar 13, 2012 | 10:25 PM
niinjoosum's Avatar
niinjoosum
My 2010 Limited with a 120r and a screaming eagle racing clutch wont hold 38 ozs, per user manual I just tried. I took out about 34ozs from the prior dealer service and always had neutral shifting issues. HD manual states just below clutch plates. Results in about a quart and a little bit. We will see.
Old Mar 13, 2012 | 10:37 PM
btsom's Avatar
btsom
I have read somewhere that the police machines used in the maneuvering contests and demonstrations get a few EXTRA ounces of primary lube because of the extra clutch slipping used in those maneuvers. A little extra is better than not enough. Each manual shows the correct level, I use a little extra. My experience with the SE compensator and ATF is not good. Those cone springs push the interacting pieces together very firmly and the film strength just doesn't seem to be there. Sure makes for a great clutch engagement though.
Old Mar 13, 2012 | 11:12 PM
bagman1's Avatar
bagman1
You do know the quart bottles have oz markings on the side? I made a measuring device from a straightened cotter pin, 2-3/4" from the center of the clutch shaft. After doing the measurement way I decided to make life easier.
Old Mar 14, 2012 | 06:25 AM
golfmajic's Avatar
golfmajic
From: Ottawa, Canada, summer, Daytona Beach Florida, winter
Yup 38 ozs, I measure.
Change the engine oil and filter every 5000 miles and primary and transmission every 10000 miles.
The primary oil always comes out with the most dirt in it I am guessing courtesy of the clutch wear!
Old Mar 14, 2012 | 07:27 AM
Neckball's Avatar
Neckball
I check to see that it covers the bottom edge of the basket
That's the correct method. Not dumping in a quart or measuring whatever ounces. It's just like checking the dipstick in your engine.
Old Mar 14, 2012 | 07:58 AM
katobird's Avatar
katobird
Cover off, on kickstand, fill it to the "basket level like dawggie said..
Comes out to the 38-39oz range.
Plus I change it with every oil change...for a qt and 1/2 more it's cheap
Old Mar 14, 2012 | 08:13 AM
frankhafer@hotmail.com's Avatar
6th Gear
What do you mean but neutral shifting issues? And what do you guys mean by "basket"?
I'm having problems getting her in neutral
