Strapless bike trailering
Old Feb 8, 2011 | 05:41 PM
Faast Ed's Avatar
Faast Ed
Do they offer to pay for any damages if it don't work? (Not bloody likely).
Looks like a gimmick that "maybe" will work okay.
Are you okay with "maybe" or "probably"?
There in lies your answer.
And if you feel safer backing it up with straps, then you have wasted money on this product.
Old Feb 8, 2011 | 06:39 PM
kanddr's Avatar
kanddr
If you decide to add tie down straps dont cheap out and buy the friction straps. Get the nice ratcheting straps that wont loosen up over time.
Good luck on your move.
Old Feb 8, 2011 | 06:56 PM
suey 1958's Avatar
suey 1958
Thanks for your Service,... I would just strap it down...
Old Feb 9, 2011 | 12:40 AM
Arvid's Avatar
Arvid
I think the Roberts will take you a long way but I would not use it alone. Couple summers ago I came across a guy that devised a rigid tie down system made out of swaged tubing, http://www.moki-ezlock.com/ It does not compress the forks and has a front tire chock. I would use that, and my trailer has D rings on either side of the rear tire so I can strap the tire stationary to the floor, and strap my front tire into a Baxley drive on chock. Between the Roberts and Moki-ezlock you should be able to stablize the top of the bike. Good luck, and thank you for your service.
Arvid
Old Feb 9, 2011 | 04:24 AM
JayStronghawk's Avatar
JayStronghawk
Well anyway have not seen any posts here that actually have the Roberts Strapless but sure seen a lot of judgement calls from some that just like to bash things.. I have used it and works great just as advertised..
Old Feb 9, 2011 | 07:50 AM
chevele72's Avatar
chevele72
Thanks for the service and enjoy the retirement!
That being said I'm not sure if the frame is going to like all that vibration and bumps over time. JMO. But as already stated, if you use the ratchet straps in conjunction with whatever system I think it's worth piece of mind. I think the strapless dock would work fine but why take the chance.
Old Feb 9, 2011 | 08:06 AM
big cahuna's Avatar
big cahuna
It seems like alot of money for something with limeted function, and how many times are you really going to use it? Straps and a wheel chock are alot cheaper, and you can use the straps for lots of jobs Imho.,,
Old Feb 9, 2011 | 11:21 AM
Sharknose's Avatar
Sharknose
A verification of Murphys Law waiting to happen, IMO.
I just wouldn't want all that unsupported weight above it, especially on a bad road. It may hold a bike upside down, but that has nothing to do with the twisting side to side forces that would be concentrated in a small area.
And maybe i've just been lucky, but I've never had problems with a good set of ratchet tiedowns becoming slack outside of needing a click or two at the first stop.
It might work perfectly--but I wouldn't volunteer my bike as the guinea pig.
Old Feb 9, 2011 | 12:37 PM
pretz's Avatar
pretz
Arvid
If I was to buy a strapless system it would be this one.
Old Feb 9, 2011 | 01:00 PM
Steamchicken's Avatar
Steamchicken
is it too late to buy a covered trailer...that's lots of rough road!!!
