Windshield too tall
Old Feb 9, 2011 | 10:24 PM
twistedcherokee's Avatar
twistedcherokee
I used a cut off tool. Just marked where I wanted it cut and cut it off, then sanded it down with a sanding block. I am thinking of putting some flames with window tint, will see how that turns out. Will try to get some pics of it.
Toby
Old Feb 9, 2011 | 11:32 PM
Garcou's Avatar
Garcou
Iam the glass shop! Mask the cut, draw a line, use a jigsaw with a plastic or metal blade, make your cut, the use a belt sander with 220 grit
Or a disk sander, sand the edge first then sand the flat, pull the tape, use some motor oil and dress the edge. Note: even if your cut develops a few burrs, your sander will clean it up, the key is to hit the edge in both sides first!!!!!! Then hit the flat
Old Feb 10, 2011 | 05:59 PM
suey 1958's Avatar
suey 1958
When I bought my RG the seller told me that he had the windshield cut a couple of inches,... It is absolutely Perfect
Old Feb 19, 2011 | 05:28 AM
Sandcrab's Avatar
Sandcrab
Default Completed
While I had the windshield off to install the new oil temperature gauge, I did what most suggested, blue painters tape, and a jigsaw, and it actually looks pretty good in the raw cut. I will sand it down today and see how polished it looks. Thanks.
Markske
Dec 29, 2011 04:40 AM
SPECIAL ED
Sep 19, 2011 12:58 PM
mrfikser
Aug 4, 2011 12:36 PM
schumacher
Nov 7, 2007 01:33 PM
mvcrez
Oct 27, 2005 03:25 PM
