Oil Temperature Gauge
Btw. Has anyone installed the gauge above? Any issues with leaks?
You can order Loctite 565 from McMaster Carr and have it delivered to your front door.
Not suggesting there aren't alternative products that might work. I tend to use what is suggested.
Are you referring to the hd oil gauge or the one from powertoys?
I have been syphering whether to put on the oil gauge from powertoys and their instructions do not include tape.
Also curious if any one has had any leak?
Thks
As I was standing there looking the bike over, I saw a cut in in my front tire and made an appt to have the bike at the shop Sat AM to get it replaced. I had not read the instructions yet and didn't know that I needed the loctite 565 or that getting it was going to be a problem. So ordering the loctite (now) is out of the question.
When I bought the Permatex last night, they had some high temp stuff, suitable to 450 degree F, but in order to remove it, you need 500 degree heat to soften the stuff, and I just didn't want to do that. I know that the pipe plug removed for the sensor was a bear to get started. Instead I bought the medium strength blue stuff, which is good to 300 degrees F and is similar to the blue Loctite I believe. I would like to at least get the sensor installed and oil added so I can either ride the bike up Sat or put it on my trailer and take it up for the tire change.
It is interesting that Power4Toys doesn't recommend any sealant or tape as they use the fitting as a path to ground. The picture shows only 1 wire to the sensor. HD has two wires at the sensor in a rubber boot, one for power and one for ground I assume, somewhere up near the gauge.
