Oil Temperature Gauge
Old Feb 17, 2011 | 03:32 PM
Sandcrab's Avatar
Sandcrab
Default Oil Temperature Gauge
I am installing the oil temp gauge, but the instructions say to use Loctite 565 thread sealant. My local Autozone doesn't have it, but I do have some Loctite 242, some teflon tape, and some pipe thread compound. Is it really necessary for the 565 or can I use the 242, or just teflon tape?
My project is in progress, right now, need help ASAP.
Old Feb 17, 2011 | 03:48 PM
easycruzer's Avatar
easycruzer
Teflon tape will do..(The yellow one as it is for fuel and oil environment.) That is all I used with no loctite.
Old Feb 17, 2011 | 03:55 PM
Sandcrab's Avatar
Sandcrab
Thanks.
Old Feb 17, 2011 | 04:09 PM
harleyiron80's Avatar
harleyiron80
what is the process for installing oil temp senser i was thinking about doing it to my flhtp thanks
Old Feb 17, 2011 | 05:04 PM
Sandcrab's Avatar
Sandcrab
Default Process
Steps: 1: get some loctite 565
2. drain oil, change filter
3. Remove the hex head pipe plug next to oil drain plug
4. Install pipe thread adapter using loctite 565
5. Install elect temp sender into pipe adapter using loctite 565
6. tighten to spec
7. Remove front fairing
8. Remove the air temp gauge
9. replace with the new oil temp gauge
10. Hook up wires, test.
11. Reinstall the front fairing.
Now this is simplified, and torque values have been omitted as I am at the computer and not in the garage. Looks pretty simple but didn't know about the loctite 565.
Old Feb 17, 2011 | 05:07 PM
Sandcrab's Avatar
Sandcrab
Default Yellow tape
Just came from Autozone and they didn't have a clue about yellow teflon tape. Bought some Permatex med strength threadlocker, which I think is similar to loctite, but may not be the right stuff. Max temp for what I bought is 300 degrees F, and i think the oil temp goes higher than that.
Old Feb 17, 2011 | 05:20 PM
69cj's Avatar
69cj
I could be wrong but if your oil temp. is in excess of 300 degrees I think you may have problems.
Old Feb 17, 2011 | 05:24 PM
Iceman24's Avatar
Iceman24
Locktite 565 is same as permatex red sealant - you'll want to use it for high-temp & strength...
Old Feb 17, 2011 | 08:50 PM
harleyiron80
yellow tape at the hardware its a plumbing thing
Old Feb 17, 2011 | 09:01 PM
indigofarm's Avatar
indigofarm
Are you installing the gauge from power toys? As, they don't recommend tape. http://www.parts4powertoys.com/OilTe...e_Details.html
Btw. Has anyone installed the gauge above? Any issues with leaks?
