Oil Temperature Gauge
My HD did not carry it, but could order it. I just needed it before they could deliver. My fault for not reading the instructions prior to starting the job.
It's white.
The same **** teflon tape is made of.
Wrap some teflon tape around the threads and call it a day.
That's all we use on oil drain bolts and these sensors.
In my opinion, that liquid teflon, 565, isn't worth a damn anyway.
It never dries to create a seal.
My thinking was 20 ft lbs for the pipe thread adapter and the electrical sensor because my torque wrench's lowest setting was 20 ft lbs.
The new oil temp gauge isn't plug and play. The wire bundle that comes with the HD kit, has two wires that run from the sensor in the oil pan along the frame up to the gauge. One wire is black (ground) and one is yellow. The sensor end of this harness has a plug that plugs into the sensor plug at the oil pan. The other end has two unterminated wires. When you have the wires run and ready to install onto the oil temp gauge, put an electrical terminal onto the yellow wire and one on the black wire, and connect to the temp gauge.
Now remember the orange and black wires from the AIR gauge connector, the directions say to cut off the connector, and put a terminal on the black wire and a terminal on the orange wire. The black wire goes on the same post as the other black wire and the orange goes on it's own post.
You end up with two black wires, on a post, one yellow on a post and one orange on a post on the new gauge.
Like Nute said, it's not that hard, but working in the limited space behind the fairing was frustrating. I kept dropping the nuts.
Do you have difficult getting the nuts off and on the terminals on the guages?
I installed an oil temperature in my '03 FLHT and had one heck of a time securing the nuts on the terminals and trying to get find space to tighten them down?
Ride In Peace
