View Poll Results: 20 dollars a good deal , buy today
Yes
18.03%
No
81.97%
Multiple Choice Poll. Voters: 61. You may not vote on this poll
Remove heel shifter cheap
Old Feb 20, 2011 | 09:48 AM
  #51
shore's Avatar
shore
Originally Posted by MNPGRider
I moved the toe shifter to the outer spine, and cut two pieces of plastic 3/4" irrigation hose the right length. One I sliced lengthwise, and cut out enough so that when squeezed together it inserted into the other, giving just the right size to slip over the shaft. No vibration rattle either using plastic. Cost nothing.
Now that's a dirty scooter!
Old Feb 20, 2011 | 03:25 PM
  #52
MNPGRider's Avatar
MNPGRider
LOL, yep, been sitting since November, except for me sitting on it with dirty, snowy boots dreaming about spring !
Old Feb 21, 2011 | 10:24 AM
  #53
trackadaptor's Avatar
trackadaptor
Did you maintain the stock OEM Rubber ? What was the Inside Dia ?
Looks like the shaft is thicker towards the outer primary ??
Old Feb 21, 2011 | 11:22 AM
  #54
Leftcoaster's Avatar
Leftcoaster
It's also pretty simple to remove the heel shifter and cut the splined shaft short enough to remount the toe lever only. Clean it up with a file and a little polishing and it looks factory. When (or if) you ever want the heel option back, the splined shaft only costs about $12. No funky looking caps or spacers and your shifter won't be too far outboard (and in the way).
Old Feb 21, 2011 | 11:51 AM
  #55
NoBoldRider's Avatar
NoBoldRider
I tried moving my toe shifter to the end of the shaft and found that it got in the way. I like it on the backside of the shaft with the heel shifter or a cover on the outside.
Old Feb 22, 2011 | 09:05 AM
  #56
trackadaptor
Old Feb 22, 2011 | 09:09 AM
  #57
dawg's Avatar
dawg
Since I moved my footboards out with a spacer kit, I wanted my lever out so the spacer behind it works best for me. You can somewhat see it here. I used a piece of anodized aluminum tubing that I stole from one of my mothers old windchimes.
Old Feb 22, 2011 | 09:14 AM
  #58
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
I'm not going to ask.
Oh HELL !!! So you live with your mother?
Just messing with ya
Old Feb 22, 2011 | 09:23 AM
  #59
dawg's Avatar
dawg
Nah, I just rummaged her basement one day while I was there.
Old Feb 22, 2011 | 12:29 PM
  #60
Leftcoaster
Originally Posted by trackadaptor
You're kidding, right?
Ya, you've got to be kidding.
