View Poll Results: 20 dollars a good deal , buy today
Yes
18.03%
No
81.97%
Multiple Choice Poll. Voters: 61. You may not vote on this poll
Remove heel shifter cheap
Old Feb 17, 2011 | 03:58 PM
trackadaptor's Avatar
trackadaptor
Default Remove heel shifter cheap
NOT SELLING THIS PART
Would you buy this Product for $ 20.00 + Shipping ?
Comes in Black , Chrome and Stainless Steel
Comes with Spring , Washer , and Slip on Part
Remove your heel shift lever quickly & easily.
This Unique design keeps the shift shaft in perfect alignment to avoid premature shaft wear, by using the Stock OEM Rubber and a Spring to retain correct tension so the shaft does not Vibrate, a problem common to similar products.
Old Feb 17, 2011 | 04:02 PM
Jinks's Avatar
Jinks
For 20 bux, sure. Or, depending on price you could just leave the toe shifter on the inside & add a cover over the end of the shaft.
Old Feb 17, 2011 | 04:05 PM
dawg's Avatar
dawg
Would I, no because I did the same thing a lot cheaper. Do I think if you were marketing it, yes you could probably get $20 for it.
Old Feb 17, 2011 | 04:33 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
The OP is NOT selling a product. He's asking if he should buy it.
Old Feb 17, 2011 | 04:53 PM
roadhog96's Avatar
roadhog96
Sorry but I like my heel shifter and I use it all the time. I use the highway pegs to stretch my legs and feet. Don't think it's worth $20 unless you just can't stand the heel shift. Sure ins't $20 worth of spacer and spring there.
Old Feb 17, 2011 | 05:03 PM
Toypuller's Avatar
Toypuller
No,
My heel shifter was on the outside of the shaft. I took it off and put a cap on the shaft.
Old Feb 17, 2011 | 05:09 PM
carpetride's Avatar
carpetride
Originally Posted by Toypuller
No,
That's what I did but I bought a different shifter from Softbrake.
I didn't have to remove the heel shifter because it just fell off by itself.
Old Feb 17, 2011 | 05:17 PM
mtclassic's Avatar
mtclassic
You can get the little cap from harley for cheaper. I did. So I guess I would not.
Old Feb 17, 2011 | 05:20 PM
Iceman24's Avatar
Iceman24
Already did...got mine @ DennisKirk - made by Coddington. Worked great & looks nice - never used heel shifter...awkward.
Old Feb 17, 2011 | 05:49 PM
Cornhusker's Avatar
Cornhusker
Same here!
