Time difference
Old Feb 19, 2011 | 09:52 AM
rm4040's Avatar
rm4040
Default Time difference
I would like to know from someone who actually changed their cam and use their original pushrods how long it took to go in from the top. Assume the gas tank is off the bike, how long and how difficult is this procedure versus using adjustable pushrods.
Old Feb 19, 2011 | 09:57 AM
Mike T's Avatar
Mike T
It's not difficult at all. It might take an hour to take the rocker assembly off if that long. Plus 30 minutes to get the intake off.
Old Feb 19, 2011 | 10:03 AM
snohomish's Avatar
snohomish
Just changed cams last weekend on mine. I had never done this before. Went thru the top as you are describing. Added about an hour to an hour and a half. Not a big deal to do at all. Just follow the book.
Old Feb 19, 2011 | 10:06 AM
mkguitar's Avatar
mkguitar
it's a matter of pulling the rocker boxes- so the cost for that time, plus the gaskets.
removing throttle body.
that is why for years a bolt cutter has been used to cut the pushrods, which are then removed in 2 pieces.
The adjustable 2 piece pushrods, slide into place then are adjusted to proper length.
the locknut can get loose, but not often if the install is correct.
given my druthers, I'd rather have the factory solid pushrods, but If I am paying for it, or doing the job myself, I'd cut the old ones out and leave the top end undisturbed-- unless i had the heads off for another reason...
and IF I was going to that trouble and expense i would probably switch to bored pistons and cylinders ( 88 to 95, or 96" to 103), which would be a matter of 15 minutes at this point.
realistically for a shop tech it could add 2 or 3 hours to pull and re-apply everything for the sake of the pushrods, that includes the time sourcing gaskets and seals
Mike
Old Feb 19, 2011 | 12:02 PM
rags's Avatar
rags
+1, time difference might even be less when you figure you don't have to adjust the pushrods when going back together. I went through the top and would do it that way again.
Old Feb 19, 2011 | 01:07 PM
cuda67bnl's Avatar
cuda67bnl
Why would you pull the intake to change cams?
Old Feb 19, 2011 | 01:56 PM
Mike's Avatar
Mike
Right at about an hour and a half, but then you get about 15 minutes back by not having to mess around with the adjustables. You can figure it adds a little over an hour to the job. If a shop does it, they will likely charge you another 2 hours labor.
Old Feb 19, 2011 | 03:35 PM
harleytuner's Avatar
harleytuner
150 bucks for the pushrods versus 2 hours shop labor plus the gaskets to re-use the stock pushrods is a no-brainer at a shop. For a do-it- your selfer it's a toss up. IMO
Cory Heath
Engine Mechanical Topics
Jan 3, 2017 01:53 PM
magnum629c
Mar 30, 2014 10:50 PM
BJB
Nov 5, 2013 02:29 AM
crazyanimal
May 6, 2013 11:59 AM
Crazy
Exhaust System Topics
17
Dec 3, 2011 01:39 PM
