Harmon Kardon Troubles
Old Feb 19, 2011 | 11:42 AM
coolerman69's Avatar
coolerman69
Default Harmon Kardon Troubles
I have an 06 UC with the Harmon Kardon stereo. Not sure if my problem is in the head unit or with the bike. It works perfectly on acc but not with the ignition in the ON position. Any ideas?
Old Feb 19, 2011 | 11:55 AM
blackswampbiker's Avatar
blackswampbiker
Have you ran a scan of it?
https://www.hdforums.com/forum/touri...on-radios.html
Old Feb 19, 2011 | 01:51 PM
Iron Cross Audio's Avatar
Iron Cross Audio
Former Sponsor
What does it do (or not do) with ignition in ON position?
Old Feb 19, 2011 | 11:32 PM
coolerman69
Ok guys i've solved the problem. In the on position it would do nothing at all. In the acc position it worked fine. The problem was a partially discharged battery. I was installing an amp last night and had accidently left the amp turned on all night. The battery only had 9 volts, not enough to power up the radio with everything else drawing juice. Couldn't see the forrest for the trees!
Old Feb 20, 2011 | 07:39 AM
1flhtk4me's Avatar
1flhtk4me
How did you wire the switched power to the amp?
Old Feb 20, 2011 | 08:01 AM
bwana1's Avatar
bwana1
HIJACK Coolerman, you need to say "hi" to Wells, Gaddis, Cliff (Earl), and the rest of the TollHouse gang for me. Be back in May.
Bwana
Old Feb 20, 2011 | 07:23 PM
coolerman69
will do. Clifford was at thirsty thursday this week. Will probably see gattis tomorrow. Goin over to his place to use the tire machine.
Old Feb 20, 2011 | 07:28 PM
coolerman69
I had temporarily wired the switch wire to the main power wire which of course was wired directly to the battery. Just forgot to un hook when i quit for the night. Oh and the alpine ktp-445 amp will not work with an HK head unit.
famous337
Audio Systems
11
Sep 21, 2014 07:16 PM
Hogpro
Audio Systems
Feb 7, 2014 09:29 AM
davidw221
Audio Systems
Aug 21, 2013 05:11 PM
wheeldawg
Jul 24, 2011 02:32 PM
NitroBerserker
Sep 22, 2008 05:24 PM
