Oil Temp!
I've said it before and I'll say it again...
A Harley engine is air cooled, not oil cooled.
#1-Huge amounts of oil does not circulate thru the engine cooloing it like water does in a car engine. Any significant amount of oil is in the lower end where it lubricates the crank and cam and this only amounts to about a cupful at any given time. Heat is generated in the cylinder & head; very little oil is circulating in that area. There's a oil passage tube about the size of a pencil running thru the cylinder jug that carries a small amount of oil to the rocker box. This is not a solid stream of oil but rather droplets & vapor and does little to cool the engine. If you want to cool the engine with oil you should pump oil thru the sparkplug because that's where the heat comes from.
#2-Hot oil is good oil! Oil needs to be hot to evaporate the moisture that will corrode the bearings & bushings. For each amount of gas you use, the engine produces an almost equal amount of water, smoe of which goes past the rings and into the crankcase. Cool oil doesn't evaporate the water.
Riding 2-up in the South in the summer doesn't require an oil cooler. I rode across OK, TX, AZ & CA last summer when it was 115*, my 200+lbs self and enough gear on the back to equal the weight of a passanger. Bike did just fine.
Waste of money.
And yeah he has like 14 bikes, all but 2 are harleys of all ages shapes and sizes. No oil cooler for me gonna save the money for a road trip
I am quoting from the 2009 HD Touring manual: Engine Specifications, Section 3.2, Page 3-3, under oil pressure:
"30-38PSI at 2000 RPM and normal operating temperature of 230 DegreesF"
Pleasse notice it is normal not optimal and normal means designed to or expected, hence I take that to mean I could run my engine at 230 degrees all day long, 24/7 and never worry about it. Normal is ok all day long, not "Occasionally" but all the time. Sorry but you are wrong.
If you're comfortable with HD's statements on oil temps that's fine, but I would like my oil to run cooler, which it does. I see 230° only rarely, like summertime in heavy traffic, but it typically stays at 180-205° while I'm moving, where on that scale depending on air temp. I think this is acceptable.
There has to be some other variables influencing a change of that magnitude.
Not to argue... I'll believe what I do... And you certainly have the right to believe what you do.
Peace!
I am in Florida so it has been about 68 to 74 lately...but even when it has been about 62 or less it still runs up to 230, but not higher!
The gauge is a Fairing mounted guage.
From what I have read and seen, Most temperature gauges from HD VARRY from one extreme to another... I would check your oil temp. with a different gauge...
As far as oil, SIN3 is a SIN(.)
It IS NOT a full synthetic as read in another post here... It is a Blend..
I use 20/50 Redline in my motor
MTL Redline in the primary
Shockproof Heavy Redline in the tranny.
signed....REDHEAD
