Vance & Hines Throttlepak
Old Jul 20, 2013 | 04:05 PM
  #41
TUCCI's Avatar
TUCCI
Originally Posted by '05Train
The TTS lists for $425, you can do better from a variety of sources. Cables can be gotten from Amazon for $10.
Sounds like another reason to stay far, far away from a PCV or a FuelPak.
Train can you really put a PCV in the same class as a fuelpak or are you talking out of your hat.....seriously man that's an insult.
Old Jul 20, 2013 | 05:14 PM
  #42
HDV-GLIDE's Avatar
HDV-GLIDE
Originally Posted by HDogg
My post code is 25050.I can PM you my full address if the shipping is reasonable.Thanks glide
Send a PM and I'll check it out on Monday......
Old Jul 20, 2013 | 05:30 PM
  #43
Smokey Stover's Avatar
Smokey Stover
Yea, I have one layin around somewhere, had to take it off when I got the PV, I may chop it up and use the connectors, the wires,connectors and casing are a lot cleaner looking than the stock connector hanging off the TB with exposed wires goin into the plug. Oh yea it worked ok, felt more like a cable than TBW.
Old Aug 13, 2013 | 09:44 AM
  #44
HDogg's Avatar
HDogg
So,any new development on this Throttlepak?I finally managed to get one off Ebay and it just here today(after 3 weeks).I'm gonna try and install it tomorrow.Are there any does or don'ts?My only concern is where can I safely stash away the unit?any ideas guys?
Old Aug 13, 2013 | 10:02 AM
  #45
HDV-GLIDE's Avatar
HDV-GLIDE
Remove the black cylinder/head brace, put the unit between the heads using zip ties to secure it to anyone of the harnesses in there, re-install the brace and your done....
Tips to remove the brace, remove the 2 rear tank bolts, lift the rear of the tank, use a small section of a 2x4 or a bunched up towel to keep the back of the tank supported. That will give you room between the tank and the brace to remove the 2 bolts holding it to the TB.
Old Aug 13, 2013 | 10:24 AM
  #46
HDogg's Avatar
HDogg
HDV-GLIDE thank you but I'm quite mechanically challenged and that to me sounded serious.Err..where exactly is this black cylinder thingy? is that the throttle body?I saw this installation video on youtube and that guy just stashed it away loosely.I suppose the unit is designed to handle the extreme engine heat?
Old Aug 13, 2013 | 11:35 AM
  #47
Thor's Avatar
Thor
I did the same as HDV-GLIDE, behind the black brace.
When you start to disassemble the AC you'll see what he means...the below pic is a sporty, but it's the same thing (was the only pic I could find on web)
(sorry about the size)
Old Aug 13, 2013 | 03:15 PM
  #48
HDogg's Avatar
HDogg
So that's the black thingy...thanks Thor and the size of the picture is excellent.Gonna give it a shot tomorrow.hang in there with me guys.These things are like rocket science to me.
Old Aug 13, 2013 | 04:12 PM
  #49
Thor's Avatar
Thor
I'll be on sporadically tomorrow....post up if you have any questions
Old Aug 13, 2013 | 08:25 PM
  #50
Blafli01's Avatar
Blafli01
3rd Gear
I installed the pack about 30 days ago. Got very tired of the throttle lag. Every time I started up from standing still at lights etc there was a delay. Guess I was too used to the immediate response from a cable actuated system from my previously owned 4 Harleys.
Install was easy as it plugs in line with the throttle body harness. Took me maybe 10 minutes including tie banding the harness and module securely.
Works great and totally eliminated the throttle delay with no effect on the PCV Maps etc. Recommend to anyone annoyed by the built in emission delay to the TBW system.
