Need help: Tour pak led light kit
Old Feb 23, 2011 | 07:41 PM
mac1842's Avatar
mac1842
Stage III
Default Need help: Tour pak led light kit
Getting ready to install the Wrap around LED light kit on my 2010 Glide limited, anyone out their have any tips, wiring directions concerning pin housing is a little vague, ie: the AMP six way pin housing calls for a white wire in cavity 6. The wiring module harness that came with my kit only has 5 wires and the white is missing. I know when I bought the GPS wiring kit from Harley they screwed up on the Pin config in the directions and I have a feeling they did the same here.
Old Feb 24, 2011 | 07:54 AM
SCJE8's Avatar
SCJE8
I've done this upgrade mac1842 and ran into the same problem...I might be able to help.
I'll shoot you a PM this morning and we'll get the details worked out!
Steve
Old Feb 24, 2011 | 07:40 PM
aviscomi's Avatar
aviscomi
I doing the same upgrade on a Paint Matched TourPak; I have the lights installed on the TourPak and I'm just waiting in the Detachable mount from Zanottis. I disregarded the portion about the white wire because if you trace it up you'll notice that there is a "blank plug" in the other connector.
Old Feb 24, 2011 | 08:07 PM
mac1842's Avatar
mac1842
Stage III
Just finished removing the original wrap around lights off the pac, what a bitch removing all the factory sealant from around the old light housings. Removing the old brake/running light wiring, trying to keep it neat for the remaining side marker lights
XSKIPRO
May 22, 2013 07:18 AM
runnhrd
Dec 15, 2012 04:13 PM
groaning
Jun 30, 2011 06:48 PM
Fattire_Biker
Electrical/Lighting/Alarm
Feb 5, 2011 10:33 PM
07blackcherryflhx
Mar 19, 2008 09:40 AM
