Melted boot on exhaust
Old Feb 27, 2011 | 10:16 AM
MNPGRider's Avatar
MNPGRider
Dip a rag in kerosene, and it'll come right off. Or, use ultra fine steel wool dipped in kerosene. That also works great for road grime, tar, etc.
Old Feb 27, 2011 | 08:43 PM
kujo58's Avatar
kujo58
1st Gear
Default Melted Boot
I did something similar last week. I had on some nylon sweats going to the gym, and melted part of it on the exhaust. I read somewhere to try an SOS pad. Fisrt I got the bike warm, and then gently wiped off the sticky mess. Only thing I had to do after was to wash off the bluish soap residue from the SOS pad. No scratches at all, and really easy to do.
Old Feb 27, 2011 | 09:25 PM
JRBass's Avatar
JRBass
Everyone has their own solution. I agree with the oven cleaner. heat the bike up spray oven cleaner on rag and wipe it off.
Old Feb 27, 2011 | 09:29 PM
Cougr's Avatar
Cougr
5th Gear
I did the same thing last year, used neverdull on it and within 2min it was gone.
Old Feb 27, 2011 | 09:40 PM
Groversue's Avatar
Groversue
I also used NeverDull
Old Feb 27, 2011 | 09:44 PM
E N AZ's Avatar
E N AZ
I use steel wool with WD-40. It comes right off with minimal effort.
Old Feb 27, 2011 | 09:55 PM
CSMHOG's Avatar
CSMHOG
Best to just remove the heat shield if you're going to use an oven cleaner. It's only held on by two 3/8" clamps and takes about two minutes to take off.
Old Feb 27, 2011 | 09:57 PM
xdanman's Avatar
xdanman
Default re
No need to heat pipes. Spray on pipes cold, hose off the next morning. Gone
Old Feb 27, 2011 | 10:12 PM
lh4x4's Avatar
lh4x4
HD has a rubber and plastic remover. About a four oz. bottle is $9.00. Saw it on the counter at a dealer.
Old Feb 27, 2011 | 10:17 PM
mphamrick's Avatar
mphamrick
Once the pipe cooled down I just a razor blade, but was really carefull with it.
KWC6
Jun 28, 2024 11:32 AM
Sharkman73
Nov 12, 2013 06:22 PM
KWC6
Sep 3, 2012 05:52 PM
OneBlackFly
Detailing
20
Sep 21, 2010 10:29 AM
ENZOTHEBAKER
Jul 21, 2005 10:39 PM
