Motor upgrade
Old Feb 27, 2011 | 02:08 PM
CURTYS06FLHX's Avatar
CURTYS06FLHX
Default Motor upgrade
Let me know what u think. Hydraulic cam upgrade, Andrews 26 cam, bore to 95 cu. in. with 10 to 1 KB pistons
Old Feb 27, 2011 | 02:49 PM
andyp's Avatar
andyp
I did a 95 in build a few yrs back on my 04 FLHtc.I have a 42 mm Mikuni carb,DTT ign,flat tops with 030 head gasket,06 heads which were street ported and milled slightly, Andrews 26 cams with Hyd tensioners,and at the time i ran true duals with Screamin eagle mufflers.I got 92hp and get this 112 ft lbs of torque.Since then I have changed mufflers to Rinehart and it has more HP .
Old Feb 27, 2011 | 03:22 PM
inverse121's Avatar
inverse121
Don't think you or your starter are gonna like 10:1 with the 26 cams. You'll definitely want a programmable ignition.
Are you planning on any headwork?
Compression releases?
If your heads are 86 ccs and you use a stock headgasket, you might like it, but I think you are gonna have detonation issues.
Old Feb 27, 2011 | 03:30 PM
CURTYS06FLHX
I have Mikuni carb true duals Screamin eagle ignition. Think i would be better off with 9.25 to 1
Old Feb 27, 2011 | 04:30 PM
inverse121's Avatar
inverse121
I think you should do some research and not just guess at what you are putting together. You can call Andrews and see what they suggest for compression ratio with those cams. There are plenty of guys running the 26 if those are the cams you want to run, you should be able to find some tried and true setups. I am not a huge fan of those cams, but if I was going to run them, I would shoot for about 9.6:1.
Can you get good gas where you ride all the time?
Old Feb 27, 2011 | 08:18 PM
CURTYS06FLHX
I can get 93 octane fuel
davidw221
Engine Mechanical Topics
31
Feb 13, 2018 03:13 PM
JP7
Jan 3, 2018 10:42 AM
whynotf75
Nov 29, 2012 10:13 PM
cdorsey50stang
Exhaust System Topics
Sep 5, 2012 06:14 PM
harleyhorn
16
Mar 25, 2011 02:10 PM
