Hogtunes amp/speaker install with pics
Old Oct 11, 2006 | 11:00 AM
rollover's Avatar
rollover
Default RE: Hogtunes amp/speaker install with pics
Yep. Have them on mine and definitely made a difference.
Pez: is the amp for 2 or 4 ohm speakers? I bought the four 2ohm replacements for my 06 Ultra but am interested in the amp. Can this be added to my current setup for more power and bass?
Old Oct 11, 2006 | 11:06 AM
RICHINTX's Avatar
RICHINTX
ClinesSelect,
Can you tell me about how long the install took?
Old Oct 11, 2006 | 07:12 PM
ClinesSelect's Avatar
ClinesSelect
Under an hour but I used to install for a living.
Old Oct 11, 2006 | 09:13 PM
ABNELECTRAGLIDE's Avatar
ABNELECTRAGLIDE
The installs are extremely easy, PEZ gives you some very good instructions to use. These things are worth the money even without the AMP i was jammin very nicely at 80mph. AMP will be installed soon.
Old Oct 11, 2006 | 09:16 PM
ABNELECTRAGLIDE
What exactly is the wire that goes to the CIG LIGHTER for ?
Old Oct 11, 2006 | 09:26 PM
kruzin's Avatar
kruzin
To power the amp
Old Oct 11, 2006 | 09:40 PM
ClinesSelect
ORIGINAL: ABNELECTRAGLIDE
Remote turn on wire. It signals the amp to turn on and off. Once the amp is on, it draws power from the B+ wire running directly to the battery.
Old Oct 11, 2006 | 11:16 PM
ldr999's Avatar
ldr999
guys I have never worked on a bike before how difficult is this install on a 07 SG--amp and speaker replacement---what tools will I need
thanks,
Lyn in ATL
Old Oct 11, 2006 | 11:35 PM
60mike06FLHX's Avatar
60mike06FLHX
Do a search of the forum, someone posted pictures. I to was afraid to attempt this until I read the post on removing the front of the fairing. (7 screws) after that its a simple unplug and plug and play.
If I can do it any one can.
Be sure you read the removal forum, a lot of good tips to keep from making a mistake.
All you need is one torx tool.
https://www.hdforums.com/m_384080/tm.htm
Old Oct 12, 2006 | 12:35 AM
alazlo's Avatar
alazlo
I have an 06 classic and upgraded the front speakers to hog tunes. Had a couple of problems with the radios (3 of them installed by Harley before I got one that worked) but now that everything is right the hogtune speakers are great. With just the front two I can hear the radio loud & clear over the exhaust at 80 mph. I reccomend them...
