Changing Shocks
Old Feb 28, 2011 | 09:59 AM
bob.hartline's Avatar
bob.hartline
Stage IV
Default Changing Shocks
I have a 2000 FLHT-C and want to replace the suspension front and rear. I would prefer to replace the stock type system. Does anyone know anything about "The Works" shocks? Similar to progressive shocks. Thanks
Old Feb 28, 2011 | 11:30 AM
SmokinRK's Avatar
SmokinRK
I have a set of Works Street Trackers (ARS & Dual-Rate Springs) on my 01 RK. I have run them for two years now and can say they are a significant improvement over the stock air shocks. I only changed out the rear, for the front I went with a heavier oil and it's fine for now.
Old Feb 28, 2011 | 09:53 PM
Harleyboyddk's Avatar
Harleyboyddk
I think any spring system will be an improvement from the air shock. After that, the more you spend, the better the results.
Old Feb 28, 2011 | 09:58 PM
Beemervet's Avatar
Beemervet
Went to Works from Progressive, it was an upgrade. For the forks, use Progressive standard height fork springs. After that, how much do you want to spend?
Old Feb 28, 2011 | 10:03 PM
103 sedona orange's Avatar
103 sedona orange
I had "WORKS" on a FXR years ago & they made all the difference in the world. I'll be getting some for my FLTRX soon.
Old Mar 1, 2011 | 11:51 AM
bob.hartline
Stage IV
I changed over to a Custom Cycle engineering swingarm bearing this winter to replace the bushing system. I guess I will try the Works both front and rear. Towards the end of last year I was ridin like a rock...obviously the HD air system has to go. Thanks for the input. Ride safe
grubsie
Oct 3, 2018 07:54 PM
beernazi559
Apr 24, 2014 11:15 PM
Meatnog
May 27, 2012 01:31 PM
desertcogo
Mar 16, 2009 11:54 AM
ridetheglide
Dec 3, 2005 12:27 PM
