New Cam upgrade???
Old Feb 28, 2011 | 07:56 PM
mad34b's Avatar
mad34b
Default New Cam upgrade???
Going with se204's when they do cam tensioner upgrade kit. What other parts will I be needing for the 204 upgrade? Thanks
Old Feb 28, 2011 | 08:36 PM
oldhippie's Avatar
oldhippie
What year bike is this? A little bit more info would be helpful.
Old Feb 28, 2011 | 08:53 PM
mad34b's Avatar
mad34b
05 Rkc with v&h slipons and k&n filter
Old Feb 28, 2011 | 10:09 PM
DTTJGlide's Avatar
DTTJGlide
You'll need some kind of tuner if you don't already have one, & have them change the inner cam bearings while you're in there. The lifters should probably be OK if the miles aren't too high.
Old Mar 1, 2011 | 04:05 AM
04 rkcrr's Avatar
04 rkcrr
Adjustable pushrods, innercam bearings and gaskets. I would put new lifters in also.
Old Mar 1, 2011 | 11:08 AM
iclick's Avatar
iclick
Reports from the field indicate that the stock 8.8:1 compression is a bit low for the 204's. They seem to like mid-9's, so you might consider a 95" kit with that upgrade which will get your compression in that territory. The only downside to the stock compression is that your low-end TQ will likely suffer.
Bikerscum
2014-2024 Touring Models
Jun 7, 2015 09:53 PM
Rogue8Man
Oct 26, 2014 06:08 AM
Jim Kraft
EVO
21
Nov 12, 2010 02:41 PM
softail99custom
EVO
Oct 23, 2009 09:19 AM
LeadDoggy
EVO
Mar 13, 2009 07:19 PM
