wheel upgrade
Old Mar 6, 2011 | 11:58 AM
motown's Avatar
motown
Default wheel upgrade
Here is the story, I own a 2000 electra glide classic, with steel spoke wheels. 1 inch bearings up front 3/4 or 25 mm in rear .got a pair of oem black mag wagon wheels super cheap ,new wheels have 1 inch bearings up front an 1 inch in rear, this should be an easy fix just pop out the 1 inch bearings out of the new rear wheel and install the 3/4 or 25 mm
that is not the problem !! looks like there could be some spacer issues
I'm sure someone has run into this before .does harley make a retro kit
with the right spacers ?
any help would be great
Old Mar 6, 2011 | 12:09 PM
Lancemchn's Avatar
Lancemchn
Not sure if this helps but I just did the same mod on a 2007 SG. I think the wagon wheels I got were off a 2001.
Old Mar 7, 2011 | 03:25 AM
motown's Avatar
motown
going to check with a couple local dealers for fitment, other than changing the rear bearings to 3/4, hope there are no spacer issues thanks
Old Mar 7, 2011 | 03:54 AM
Holzarbeiter's Avatar
Holzarbeiter
I did the same thing on my 2000 RK classic, no spacer issues
Old Mar 8, 2011 | 03:27 AM
motown's Avatar
motown
well so far so good , did a dry run last night with the front wheel and brakes, everything was fine
going to install new 3/4 rear bearings, mount the drive pully and disc, we'll see what happens
gant
Aug 17, 2015 02:20 PM
TimHixson
Wheels/Tires
Jun 23, 2013 05:49 AM
WaltD13
Wheels/Tires
Apr 10, 2013 04:01 PM
jrpitty
Oct 13, 2012 01:53 AM
Badass67stang
Jun 22, 2011 08:08 AM
