wsample
Old Mar 15, 2011 | 11:09 AM
wsample's Avatar
wsample
Stage I
Angry wsample
I JUST PURCHASED A 2006 ELECTRI-GLIDE CLASSIC CONVERTED INTO A LEHMAN TRIKE IT WAS ADVERTISED AS A 95" MOTOR.
hOW DO YOU CHANGE FROM 88" TO 95" ? And IS THIS STANDARD PROCEDURE?
Old Mar 15, 2011 | 11:15 AM
89FLHT's Avatar
89FLHT
Bigger jugs and pistons, be happy, it will have more power to pull the trike around. Get the upgraded hydraulic cam tensioner setup to make the cam chest rock-solid and go ride the hell out of it.
Old Mar 17, 2011 | 11:31 AM
Beemervet's Avatar
Beemervet
Turn off your caps, cheer up, and ride the damn thing.
Old Mar 17, 2011 | 11:33 AM
kilocharlie7's Avatar
kilocharlie7
Default Hydraulic Cams
I was told the '06 motors (except the B) already had hyrdaulic cams tensioner.
Old Mar 17, 2011 | 12:07 PM
hdelectra's Avatar
hdelectra
My '05 EGC came stock with the 88cid. I purchased the Stage II Big Bore Kit (95cid) and it installed and the difference was HUGE. Especially low-end torque.
Back in the day, the 95cid kit was what was used for Screaming Eagle bikes, BEFORE they started splitting the crank case and changing out the crank. When they began doing that, that's where the 103cid's came from.
Old Mar 17, 2011 | 12:16 PM
89FLHT's Avatar
89FLHT
The Dyna got the hydraulic cam tesnioners for 06, the 'glides still had the spring tensioner set up from everything that I know of and they were converted to hydraulic for 07 when the 96" came out. (If I'm wrong at that, my bad, I'm just pretty sure that is the real deal. )
Old Mar 17, 2011 | 02:26 PM
kilocharlie7
Default I think you're right
I have an 06 Dyna, so that would fit. I think you're right. Makes you wonder why they didn't outfit all the 88 non B's at the same time.
hogkrazy
Exhaust System Topics
14
Mar 28, 2012 05:38 PM
mwsanford
Mar 14, 2012 03:02 PM
remmag
Feb 24, 2011 05:58 PM
reecard
Aug 12, 2008 10:05 PM
uniondog
Mar 8, 2007 12:34 AM
