HELP! I need more handlebar pullback before Laughlin
Old Mar 19, 2011 | 06:47 PM
pargenz's Avatar
pargenz
Jenna,
I'd suggest one of two things: if you like Wild Ones, give them a call. They are helpful folks. Secondly, check out Hill Country Customs - they sell their bars as kits with all cabling to match.
Then find a local indy to do the install.
Old Mar 19, 2011 | 08:10 PM
BackAt5O's Avatar
BackAt5O
I put Wild One 508 on my 2007 Road King. I ran all wires internally, no wire extensions needed, used original clutch and brake lines. 6 hours start to finish.
Old Mar 19, 2011 | 08:18 PM
vistavette's Avatar
vistavette
Originally Posted by Tuceaux
Whatever you do, don't buy the HD pullbacks, they will severly twist
your wrists to the inside.
Not true. I put the hd pull back bars on my 09 ultra and they are fine, different wrist angle than the stock bars but fine. I'd say it took about three hundred miles to get used to them but that was after 20k on the stock bars. Mother Road in AZ did the job for $535 and all I needed was the longer clutch cable and a new left grip.
Old Mar 19, 2011 | 10:27 PM
smithbrl's Avatar
smithbrl
I couldn't do the $1100 mod with the dealer-too much money. I bought the HD pullback bars, $150 and did the job myself. Took a while but I ran the wiring internally and reused the stock brake line. The clutch cable was kinking slightly when I turned the bars hard left so I had the dealer install a new clutch cable. I didn't think it would be a problem but changed it for peace of mind. Cost for everything was about $320.
I don't remember having any trouble getting used to the bars. No problem with wrist angle. They fit me fine and they got rid of the burn between my shoulder blades. I'm happy.
Cecil
Old Mar 20, 2011 | 04:45 AM
garand's Avatar
garand
I'm happy with the HD pullbacks. I kept it wired externally, with the exception of the TBW or course. I changed grips as well. I didn't need to purchase a new brake or clutch cable either. Overall it took me 3 hours and about $250, because I bought a new set of grips as well.
Mark Almond
Jun 5, 2019 08:27 AM
X Iron Butt
Oct 24, 2013 06:47 PM
vickers1
Dec 11, 2012 08:55 PM
Geezer glider
Apr 2, 2011 05:08 PM
S&RSGLIDE07
Feb 7, 2011 08:02 PM
