Removing Fork Tube Plug
Old Mar 19, 2011 | 04:35 PM
MiracleMax's Avatar
MiracleMax
Default Removing Fork Tube Plug
How the hell do ya do it? I've tried everything short of a pipe wrench to keep the tube from turning, with no luck. Finally I decided to bite the bullet and shell out the 20-25 pesos, or whatever HD wants for the clamp. That is until I went to buy it! $149.99!! Are you kidding me?! There isn't a bullet made that would make that easier to swallow. So the question is... any suggestions?
Old Mar 19, 2011 | 08:15 PM
MiracleMax's Avatar
MiracleMax
I know some of you have powdercoated their fork legs and been through this before. There has to be a way to take them apart without buying this clamp. How did you do it?
Old Mar 19, 2011 | 08:37 PM
Lonewolf176's Avatar
Lonewolf176
Just hold them with the bottom part of the triple clamps. You can also drill a 1 9/16" (41mm) hole in a 2x4, then cut it in half and clamp in vice.
Old Mar 19, 2011 | 08:49 PM
rg_dave's Avatar
rg_dave
Take the top fork cap out. Drop the fork in the tripple clamp a couple of inches. Tighten the triple clamp. Loosen the spring cap. Drop the fork. Have a friend hold the tude and remove the cap. Keep your hand on top of it so it doesn't pop off.
Old Mar 19, 2011 | 10:43 PM
All Aces's Avatar
All Aces
I looked at the harley tool and just took some hard plastic and cut a V notch like HD did. I used a thin piece of rubber from a door weather strip. Wrapped the tube with the rubber, put the clamps around it and held it in place with my workmate bench. A quick hit on the wrench with a hammer and it came loose fast. Pic. attached
Old Mar 19, 2011 | 10:55 PM
EasternSP's Avatar
EasternSP
Just need a good throttle hand to hold it.
woody1978
Jul 10, 2017 12:07 PM
Sandcrab
2014-2024 Touring Models
21
Jun 22, 2017 02:16 PM
laabdog
Apr 15, 2017 10:02 PM
stev0n
Jul 8, 2011 05:07 AM
hell hound
Jan 16, 2010 04:35 PM
