Gas quick couple problem
Old Mar 27, 2011 | 01:27 PM
ultrafire's Avatar
ultrafire
2nd Gear
Default Gas quick couple problem
i have an o7 harley ultra which since it was new it would ping in the mountains. 3 times it would not start and i had it towed 2x to the dealer and they disconnected and reconnected the quick couple off the tank and it ran fine for a couple of months. last year it quit several times and i dis and re connected the coupling and it ran for a little while. i took it to the dealer and they replaced the quick couple after replacing the vent valve (the vent valve was not the problem) and i had to return to the dealer the same day. But since the coupling was replaced the bike runs better and stronger, does not ping at all, and has not had a fuel problem since. The old quick coupling i could move up and down a bit like it was loose. the new one is very tight.
Old Mar 27, 2011 | 03:03 PM
smithbrl's Avatar
smithbrl
Thanks for the info. It's something to keep in mind if that sort of problem arises.
It would have taken me a long time to figure that one out. How long has it been since it was "fixed"? How many miles?
If you think about it, post again in a few months to let us know if that was the final fix for this problem.
Cecil
Old Mar 27, 2011 | 03:12 PM
TLONG's Avatar
TLONG
Yea i have a 06 Ultra and it cost me a 75 tow bill,towed it to local Harley dealership and showed me the same problem.Harley didn't charge me anything but now i feel uneasy about it happening again everytime i ride.
Old Mar 27, 2011 | 03:20 PM
n8dc's Avatar
n8dc
FWI
I used to work were they made the disconnects. I helped design and build the machines to assemble and test them .. There can be a couple issues with couplings like the ***** wearing and letting the coupling close enuff to slow or stop fuel flow. They also if decoupled a lot and not re coupling them keeping the fitting as straight as possible can shear the outer o-ring causing fuel leaks. Seems the o-rings dont like ethanol either.. Ive helped a bunch of guys out here repair the fittings o-ring wise but if its a problem with the ***** being wore to the point of decoupling the fittings somewhat to cause little or no fuel flow then thats a replacement fitting to cure the problem.
Happy riding
Whiskyjock
Dec 23, 2017 11:22 AM
Navyrep1
Jul 11, 2011 02:27 PM
Fr3shFr0st
Aug 22, 2007 12:32 PM
Zeb
May 16, 2007 06:34 PM
TickTock
Mar 20, 2007 07:54 AM
