removing battery
Old Oct 17, 2006 | 01:07 AM
waltr's Avatar
waltr
Default removing battery
I cannot believe the battery and the positive and negative terminal position on my '07 Ultra. Any suggestions to make this job easier? There is simply no room. I am planning on adding a strap to air in battery removal next time.
Old Oct 17, 2006 | 01:12 AM
pittguy's Avatar
pittguy
Default RE: removing battery
Some install the angled copper brackets
Old Oct 17, 2006 | 01:16 AM
Bryan TTM's Avatar
Bryan TTM
do this....you can take off the positive...the batts heavy...use the neg strap(loosened) to pick the batt up...it will come up about an inch or so allowing you to completely take off the neg...if you look theres a hole where the harness goes thru right above and behind the oil fill cap...get a pry bar with a flat blade on it...have a buddy carefully hold the bottom of the batt thru that hole(bottom of batt tray)...to re-install
HDSledge
Electrical/Lighting/Alarm
15
Jul 30, 2019 11:26 AM
Hawg6
Aug 16, 2014 06:26 PM
rwhite15
Oct 18, 2010 06:54 AM
SkeeterB767
Oct 31, 2007 06:10 PM
msfreddo
Feb 15, 2007 12:33 AM
