ABS brake line
Old Mar 29, 2011 | 04:11 PM
HighLiner's Avatar
HighLiner
Default ABS brake line
What's my options for upgrading to braided front brake lines on a ABS bike? Is there an option to replace just the lower line or is it all one piece from the factory?
Old Mar 29, 2011 | 04:15 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
do what ever you want , there is no difference in the lines just get the right lengths
Old Mar 29, 2011 | 04:17 PM
harleycharlie1992
I take that back, it comes from the abs pump and its all one piece! sorry, I was thinking of something else!
Old Mar 29, 2011 | 04:19 PM
harleycharlie1992
you can changbe the line from your master cyl, and from the pump to the calipers but you will have to use multiple connectors (banjo fittings) to make it work, I changed my line from the m/c to the pump, and that was a little work, but very doable
Old Mar 29, 2011 | 04:59 PM
ny2az's Avatar
ny2az
I have an almost new Diamondback braided line from the calipers to the abs pump for sale if it is what you want...let me know...pm me...thx
Old Mar 29, 2011 | 08:03 PM
av1025's Avatar
av1025
Magnum brake lines makes lines (available out of drag)..a line from the master cylinder that is available in different lengths that connect to a pre-measured line that runs back to the box, and they have the return line from the box to the calipers..again pre-measured. Very easy when they do all the work!
Old Mar 29, 2011 | 08:44 PM
HighLiner's Avatar
HighLiner
So I can replace the line from the abs pump to the front calipers and leave the other line alone?
Old Mar 29, 2011 | 08:52 PM
porkchopsd's Avatar
porkchopsd
you certainly can, I just changed out my bars and I had the option of just doing the upper line and leaving the lower lines alone, I was going steel braided so I change them both out, the HD bottoms are very expensive like 200 bucks.
Old Mar 29, 2011 | 09:33 PM
FDHOG's Avatar
FDHOG
Make sure you get the gaskets for ABS brakes. THey are supposedly different from std.
If you're doing it yourself, you might have to visit the dealer to reprogram the ABS module if you change anything back to the module itself.
Old Mar 29, 2011 | 09:39 PM
lp's Avatar
lp
So what are you trying to accomplish really? It's not a very common question is why I ask. Most are doing bars and need an extended top line and not the bottom lines. And if they need bottom lines its usually because of appearance and therefore replace both top and bottom so they match.
Just curious?
lp
