valve clearance noise
Old Oct 17, 2006 | 09:25 PM
dgriffith's Avatar
dgriffith
Default valve clearance noise
My stock engine is quiet, no lifter/valve clearance niose when it is cold. Yet when it is hot it pecks like the lifters are weak, Running it at highway speeds it will quiet down. But putting around town it gets noisy. Can I replace the stock lifters with some better ones and adj. pushrods? any suggestions??? thanks.
Old Oct 17, 2006 | 09:41 PM
g money's Avatar
g money
Account Retired
Default RE: valve clearance noise
Mine is the exact opposite. Noise when cold. No noise when hot.
Gary D.
Old Oct 17, 2006 | 09:46 PM
Mr Wonderful's Avatar
Mr Wonderful
Feuling brand lifters are highly respected and they also make a very nice oil pump. You can buy these as a package deal or seperately. Adjustable pushrods are a good idea to help quiet what you already have......if they are dead solid perfectly adjusted.
Old Oct 17, 2006 | 09:47 PM
Bryan TTM's Avatar
Bryan TTM
steve has new life time warranted lifters for 100 bucks...i use Jims ProLite adj pushrods... www.GMRPerformance.com
Old Oct 17, 2006 | 10:02 PM
springer_'s Avatar
springer_
If you run synthetic oil, try a good 4 stroke motorcycle dino oil on your next oil change. See if it resolves your noise. If it does not, you can always switch back. It is an inexpensive test. I have noticed this when I run synthetic as well. If you are in a warm environment (Florida, Texas etc...) straight 50 weight can be good choice as well.
Old Oct 18, 2006 | 10:33 AM
huffhuff's Avatar
huffhuff
roller lifters are inherently noisey even though they are hydraulic. if you are running adjustable pushrods you can shorten them a turn and possibly they will be quieter (an S&S recommendation).
JONNIEROCK
Dec 30, 2013 06:35 PM
NECaveman
Dec 2, 2012 03:37 AM
TedMan
Exhaust System Topics
40
Apr 16, 2010 01:12 PM
97classic
EVO
Jul 14, 2009 02:17 PM
jjb
Jun 13, 2009 06:59 AM
