Dummy needs help
Old Apr 2, 2011 | 08:27 PM
buchb's Avatar
buchb
2nd Gear
Default 1 7/8
Originally Posted by bagger76
Yep 55 ft lb isn't nearly enough thats just the set torque then turn it another 30 to 40 degrees.I had to use a breaker bar and some pipe just to get 30 degrees.Is the nut around 2 1/2 inches
The nut is 1 7/8 and requires a special socket to reach in over the main shaft. I am going to pull this off one more time. Set the torque to 55 and turn an additional 30 to 40 degress as indicated. I will start by marking the current position and let you know how close I was.
Old Apr 2, 2011 | 08:54 PM
bagger76's Avatar
bagger76
Use some locktite.I used red, only takes a drop or two.
SummitRK
13
Apr 27, 2020 07:56 PM
ZOEY
Exhaust System Topics
Oct 6, 2016 07:27 PM
Nnmharmon
Sep 30, 2014 09:51 PM
robvg
Mar 26, 2013 07:51 PM
128auto
Aug 17, 2008 02:42 PM
