drivebelt help
Old Apr 4, 2011 | 09:56 PM
mthomassr's Avatar
mthomassr
Default drivebelt help
need to adjust my drivebelt have service man. have tension tool but still a little confused about procedure book says to lift rear tire .instructions with tool says to stand bike up and have someone sit on it.if i jack it up do i need to support the swingarm or let it hang
Old Apr 4, 2011 | 09:59 PM
soos's Avatar
soos
On the lift you let it hang.
Old Apr 4, 2011 | 10:08 PM
CYCLE's Avatar
CYCLE
1. At the lower strand, mid-way between transmission sprocket and rear wheel sprocket, apply 10 Lbs. of upward force on lower span of rear belt. Harley-Davidson has a BELT TENSION GAUGE (Part No. HD-35381) to help.
2. Measure belt deflection "UP and Down" several times, each time with belt moved (by rotating rear wheel) to a different position on sprockets. With sprockets rotated to tightest belt position, belt deflection should be 5/16-3/8 in.
Enough said?
Old Apr 4, 2011 | 10:12 PM
mthomassr's Avatar
mthomassr
thanks for the input soos
Old Apr 5, 2011 | 04:10 AM
grbrown's Avatar
grbrown
The tool is a funny thing to use. You need two pairs of eyes! Lightly hold the tool against the belt so you can see the tool through the slot in your belt guard. See where the tool is on the graduations on the guard. Now look at the end of the tool and press the end of it upwards, against the spring pressure, until it has compressed as far as the black line. Holding the tool steady, now look again at the slot in the guard, to see how far the belt has deflected.
Old Apr 5, 2011 | 07:00 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Enough said?
per the manual, a SG belt could be set at the low end of 1/4"......
Fine09
Feb 10, 2017 07:44 PM
Jameson
Oct 3, 2014 11:37 AM
1forrest1
Sep 12, 2013 11:14 AM
big_e78
Mar 10, 2010 09:33 PM
kjkustoms
Dec 6, 2008 07:26 PM
