removing the cat.
Old Apr 5, 2011 | 08:06 AM
24u2nv's Avatar
24u2nv
Default removing the cat.
will removing the cat. void the warranty and or set off a check engine light?
Old Apr 5, 2011 | 08:17 AM
skratch's Avatar
skratch
warranty? depends on how much of a a** the dealer wants to be.....
check engine light? nope.
Old Apr 5, 2011 | 08:19 AM
HDThunder's Avatar
HDThunder
Probably varies by dealer as far as the warranty being void. In theory they could only deny a warranty claim if they can prove the removal of the cat caused the problem.
No to the check engine light. There is no O2 sensor aft of the cat to check its function like there would be with an OBD2 based ECM.
Old Apr 5, 2011 | 08:44 AM
jamesroadking's Avatar
jamesroadking
Does not cause a check engine lite. You can even unplug the O2 sensors without causing a check engine lite.
Old Apr 5, 2011 | 08:50 AM
24u2nv's Avatar
24u2nv
does the engine run alot cooler without the cat?
Old Apr 5, 2011 | 09:04 AM
skratch's Avatar
skratch
no, the engine does not run cooler. however, the exhaust does. i ran my bike without a cat, no stage 1, just a nightstick slip on for almost a year.
Old Apr 5, 2011 | 08:16 PM
JohnScrip's Avatar
JohnScrip
Exhaust runs a LOT cooler -- Add the SE high-flow/download and get even a little cooler yet (including the motor).
Atlaska
Nov 6, 2015 09:38 AM
LakeRosemound
May 25, 2013 06:01 AM
08bluepearl
Aug 6, 2009 12:20 PM
fkind1
May 6, 2007 10:56 AM
MottyRutt
Jul 12, 2005 11:39 AM
