Check engine light
Old May 24, 2013 | 08:59 PM
LakeRosemound's Avatar
LakeRosemound
Stage II
Default Check engine light
Check engine light is coming on, dealer got this code on readout PO154
Which is supposed to signal rear O2 sensor issue. It an 06 street bob bought it 6 weeks ago with 12 k miles. Bike runs great. Dealer reset to clear on, but engine light came on hole riding back home?
Any thoughts..
Thanks
Old May 24, 2013 | 09:01 PM
purpledeuce's Avatar
purpledeuce
Should still have some warranty, have the dealer replace the sensor
Old May 24, 2013 | 09:19 PM
Rustell's Avatar
Rustell
I hope the dealer didn't just reset the codes and send you on your way...
If they did...they surely shouldn't have charged you anything.
OP's bike is an 06... 7 yrs old ,I doubt he has any warranty left.
I would reset the codes...check the connections..if it throws the code again..change the O2 sensor. And find a different Dealer
Old May 24, 2013 | 10:39 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
Thats what warranties are for! Take it back and get them to fix it.
Old May 25, 2013 | 06:01 AM
Roadie53's Avatar
Roadie53
My thoughts also. Code says O2 sensor so check the connections first then replace the sensor.if needed.
Just clearing the codes doesn't make the problem go away.
Hope is just a simple fix which is what it sounds like.
Old Iron Man
Milwaukee Eight (M8)
Jul 21, 2018 04:41 AM
thamer williams
Jan 17, 2018 07:13 PM
24u2nv
Apr 5, 2011 08:16 PM
08bluepearl
Aug 6, 2009 12:20 PM
HilllBillly
May 10, 2009 04:59 AM
