However, more impotortantly, when riding, always lean to the left to fart. This way, your gas is expelled to the right, away from the spark plugs reducing the risk of an explosion!
Starting: Ignition>Run switch, wait for initiating leds out.
Stopping: Run>Ignition switch
Helps reduce in-rush currents to the electronics.
I've had a few customers who had issues due to just using the ignition switch. Albeit, only a few.
On all my Harley's I have always used the ignition only, never had a problem. When I took delivery of my new RK the service guy made a big deal about doing it just like 'blkfalc4' said, and for the same reasons. So I think I will do it the new way... but I got to say it don't make a lot of sense to me.
Sorry for the resurrection but i didnt hear ANYONE mention this in any of the multiple discusions on the board.
I grew up riding dirt bikes since i was 3 yrs old. We never had an ignition switch, we didnt even have a battery or lights! All we had was a kill switch. It killed the power to the coil. It always left gas in the heads and it would seep into the oil. Then when i got into race cars i had all kinds of switches, first i would turn on the power then my fuel pump, then the power on, all separate switches. When shutting off the vehicle we "killed" the fuel first to starve the engine so the leftover gasoline wouldn't seep past the rings into the oil and fill your oil with gas ruining the oil after time. Then we turned off the power. We had all the switches labeled 1-2-3. Till this day i use the "kill" switch first out of habit from my race car, then i shut off the power after i starved the engine of fuel and also to keep the gas out of the jets. I do the same thing with my weed eater before i store it for the winter, i run it dry, saves my jets.
Reason: made a correction.
put 20k on my old 06 sporty killin it with the key never had a problem and my flhtci has close to 40k on it and i turn it off with the console....never touch the lil black switch...once again never a problem.... backfires in the airP breather occassionally but thats only when its 110 outside and the bike had been running and only go into a gas station for a minute and come back out to restart
If you have to replace one or the other the kill switch ***. is about 35 bucks. The console switch with fork lock, you do want them keyed alike, is app. 160 bucks. Do the math. Functionally I don't think it matters.
After you use the kill switch do you then turn your ignition switch off or do you leave it on all the time?
**** I just realized this thread was over a year old. Considering the logic the poster who resurrected it is using it isnt surprising he brought it back.
I saw this last year and am surprised at some of the answers.
I guess if you don't ever use your kill switch you wuold not notice that if it is off the fuel pump does not cycle and pressure up the fuel rail or power up the ECM (check engine light) when you cycle the ignition switch to the start position. As I cycle the ignition switch sometimes to "ON" or the "ACCESSORY" position not intending to start the bike I prefer to be in the habit of having the kill switch in the off position to keep these cycles from taking place. I also like to start the bike after the radio powers up but before the check engine light goes out. Per iclick's suggestion on this forum with the PC it seems to start more consistently and with less cranking if started before the CE light goes out. I don't go back as far as no factory installed kill switch on my older bikes but there is a lot of cht on these newer bikes that just arent the same amd can not be compared. BTW my shovel's coil was hot with the KS on and those coils got too hot to touch after about 15 min. powered up. JMO
Using the kill switch is the number one cause of a dead battery for guys in my age group. One guy in particular. If I had a nickel for every time I have said, “Hay, Danny you left your lights on!” I would have a 124 built motor.
Seriously though, I think kill switches are a throw back to the days before bikes had tilt switches that kill the motor in the event of accident or dropping the bike. All of the motorcycle courses still teach using the kill switch, I believe, to establish muscle memory — whatever you normally do you will do in an emergency without even thinking about it.
I think that if I had a run-on condition, a stuck open throttle, my dominant muscle memory would be to pull the clutch in — something that riders do many multiple times over using a kill switch. If the bike was down and the concern was the rear tire rubbing against flesh I trust the tilt switch to kill the motor.
Then there is the potential problem of resetting the idle with FI bikes.
This is, of course, my observation / opinion only.
EDIT: Oh jezz I just noticed that I replied to this thread 04-08-2011.
