Kill switch or console switch
Old Mar 23, 2012 | 11:31 PM
  #51
X Iron Butt's Avatar
X Iron Butt
Originally Posted by Potato_Potato
Using the kill switch is the number one cause of a dead battery for guys in my age group. One guy in particular. If I had a nickel for every time I have said, “Hay, Danny you left your lights on!” I would have a 124 built motor.
I used to leave the key on years ago when the head light wasn't always on. Only did it at home when I could leave the key in. After I rewired and hooked up my kill switch I quit killing coils and batteries. I got in the habbit of locking my front end now when I get off so it kinda makes me turn the ignition switch to the off/lock position. With my big *** seat and a backrest I have to get on and off from the right side so it is easier if the bars are locked to the left.
Old Mar 24, 2012 | 02:41 AM
  #52
Hog Heaven's Avatar
Hog Heaven
Originally Posted by mastery
Lots of discussion threads on this already, use the Search feature if you want to read hundreds of responses.
Yea, I can speak from a bit of experience as I started one of those threads a year or so ago. Most people were pretty cordial but a few guys were downright pizzed that I would ask such a stupid question. I actually did laugh when I read those responses since I was only wondering why it would really matter how you turn off the bike.
Old Mar 24, 2012 | 04:54 AM
  #53
dickey's Avatar
dickey
easier to hit the kill switch than fumble around with your hands off the handlebars for the console switch. I cannot see any difference
That's a buncha crappadoola. If someone is such a spaz that he can't manage to turn off the tank switch without "fumbling around', he shouldn't be on a Harley.
I was always warning my ex about NOT using her kill switch on her RK at all. Told her to forget it's there. "Why?" she asks. I told her "'Cause as sure as **** stinks in July, you're gonna hit the starter by mistake while the engine's running". What do you think she does the next time she takes my Fatty out for a ride? You guessed it. Whatta bim. Man pays for it; woman ruins it.
Told my buddy the same thing when he got his first HD, an '04 Roadster. Pulls up to me the next day,goes to kill his motor & hits the starter. You can't fix stupid.
FORGET THE FRIGGIN THING IS THERE!!
Old Mar 24, 2012 | 03:18 PM
  #54
speakerfritz's Avatar
speakerfritz
kill switch is easier to replace than ignition switch.
Old Mar 24, 2012 | 03:22 PM
  #55
leon anthony's Avatar
leon anthony
I use the kill switch just because it is right there under my thumb and i can hold the front brake on while i turn the engine off
Old Mar 24, 2012 | 03:38 PM
  #56
wlibert's Avatar
wlibert
I usually pee standing up unless I wake up in the middle of the night, have to pee, and I am half a sleep, then it's easier if I just sit down on the john to pee since I know the seat is always done for the wife. I have fallen back to sleep sitting there on the john though and eventually I fall over on the floor.
Old Mar 25, 2012 | 01:34 AM
  #57
Devo6684's Avatar
Devo6684
It might be easier to replace but you are still forced to use the the console switch.
I always use the kill switch first- I guess it is just habit from my metric days.
Old Mar 25, 2012 | 05:55 AM
  #58
VTL nut's Avatar
VTL nut
Originally Posted by bpez317
Handlebar switch is there for safety. Check out the schematic. Both switches go through the same relays and turn it off through the ECM.
Well done bpez,
mystery solved.
The only thing they may be looking at by "recommending" is looking at the loading through both switches and it may lighten the load on the keyswitch to 1st use the killswitch?
They are probably just considering life cycles versus loading on the contacts through both, and recommending for longest life. They have been known to look out for us a time or two, haven't they?
Old Mar 25, 2012 | 05:30 PM
  #59
one-up's Avatar
one-up
Operators manual says to use the kill switch then the ignition switch when shutting down. That's what I do, generally.
soulpatch
May 27, 2019 01:14 AM
Nomad1963
2014-2024 Touring Models
88
Jan 25, 2018 07:30 AM
smat45
Apr 30, 2017 06:28 AM
28gauge
Feb 18, 2009 03:04 PM
Sketz
Sep 3, 2008 08:22 PM
