Help! Clutch problems
Old Apr 9, 2011 | 05:01 PM
cgsnipe01's Avatar
cgsnipe01
Stage III
Default Help! Clutch problems
I have a 97 Ultra Classic. It's been sitting for a little over a year while I had some body work done and made some other cosmetics repairs. I've been riding it for about a week when the clutch started to be come slack and very hard to shift. while stopped with the clutch in the bike trys to move and stalls. I have adjusted the clutch according to the service manual, I've inspected the ramp system and replaced the clutch cable. After adjusting the clutch again it seemed, at first, that this was the fix. I took it out for a shake down and as it warmed up the clutch began to become slack again. I could hear a little squealing noise coming from the clutch when engaged. the more I rode the less pull I had and the harder it became to shift. I'm guess the next step is to change the clutch pack? However, I'd like to be sure there isn't something I'm missing before I go that route. If anyone has any suggestions, I'd really appriciate it.
Old Apr 9, 2011 | 05:17 PM
Other Sheep's Avatar
Other Sheep
Try changing the fluid to B&M Trick Shift Automatic Trans fluid. It's a lot cheaper than a new clutch. Sounds like the plates are trying to stick.
Old Apr 9, 2011 | 05:47 PM
Gator454's Avatar
Gator454
Have a friend go over the clutch adjustment procedure with you, just to make sure that you haven't missed a step or procedure. I've been there and done that!
Last edited by Gator454; Apr 9, 2011 at 05:51 PM. Reason: Answer was not appropriate for the problem
Old Apr 11, 2011 | 06:32 PM
cgsnipe01's Avatar
cgsnipe01
Stage III
I appriciate the responses, I'm begining to believe that I have some plates sticking as well. Is the B&M trick shift automatic transmission fluid something that should be run for a short time until the stiking stops or can I run this oil full time?
Old Apr 11, 2011 | 06:54 PM
mfortkamp's Avatar
mfortkamp
it sounds like to me something is letting loose in the clutch/linkage. maybe a clutch plate is hanging up not real sure. if it were mine i would take the cluch apart and inspect the plates and the release rod going from the ramp to the clutch
Old Apr 11, 2011 | 07:15 PM
Uncle Larry's Avatar
Uncle Larry
Along with the others I would suspect the culprit to be stuck "frozen" clutch plates. It's pretty common on scooters that have sat for an extended period. Generally taking the bike for a ride and getting the oil warm will help alleviate the problem. What usually happens is all the oil lays low in the primary and the plates that are exposed tend to rust from humidity and the friction material will "bond" to the clutch plates. Once the oil is warm and circulated the problem goes away. Get it warm, ride in an area of little to no congestion, then get it back home and change the primary fluid. It should do the trick. Don't forget to check the adjustment also just to be sure. Good Luck Brother.
Old Apr 11, 2011 | 07:16 PM
Bankrupt's Avatar
Bankrupt
How do you inspect the release rod?
Old Apr 29, 2011 | 05:04 PM
cgsnipe01's Avatar
cgsnipe01
Stage III
Default Thanks
Thanks for all the responses. I finally figured it out! It turns out the shift linkage rod was worn pretty good. I took it all down and pushed the rod out and all this crap came out with it. I ordered a new push rod and bearing for the ramp side. I cleaned all the clutch plates and re-installed it all. It works like a champ! the old rod was a little over a 1/4" shorter than the new one. I'm not sure what caused this wear but, I'll be sure to keep an eye on it.
Old Apr 30, 2011 | 07:37 AM
kyote's Avatar
kyote
Are you referring to the adjustment rod under the derby??
I have run out of adjustment on my clutch cable, the adjuster is as far as it can go without coming apart....is hard to get into neutral when warm..has a new clutch..so I know its not that.. just wondering if this may be my problem..
Slammed-N-Senseless
EVO
Aug 13, 2013 10:00 PM
Oldsarge29
Oct 28, 2012 11:07 PM
blackdresser
Jun 6, 2011 08:39 PM
lou1
May 19, 2008 03:00 PM
flyboyjacko
Sep 15, 2007 04:59 PM
