passing lamps
Old Oct 20, 2006 | 11:06 PM
bdjhog's Avatar
bdjhog
Default RE: passing lamps
ORIGINAL: ldr999
can someone post pictures and parts numbers.
thanks
This is the kit I used on my 2006 Street Glide: P.N. 69818-06 Auxiliary Lighting Bracket Kit
I reused my stock turn signals and you will have to buy your choice of auxillary lamp bulbs. I went with the smoked bulbs P.N. 68273-03A click me but there are many other bulb configuaration to choose from click here
If you have a Street Glide the kit above and your choice of bulbs is all that you have to buy. You do NOT have to buy the bullet turn signal kit.
Old Oct 20, 2006 | 11:08 PM
asuperheat's Avatar
asuperheat
Only pic I have handy that some what shows my lamps just installed them last week I got them for my b-day easy install just follow instructions you will probably need a service manual or inquire on here how to remove your ignition switch to install the supplyed switch dot have part# handy but the h-d web site will list the right ones.http://i95.photobucket.com/albums/l1...IM000220-1.jpg
Old Oct 20, 2006 | 11:15 PM
bdjhog's Avatar
bdjhog
ORIGINAL: dionne51
I believe it is 69227-04A but would like a confirmation from someone who has already purchased and installed it.
This is NOT the kit that you want to buy for your Street Glide. This kit is for other touring bikes that already have the passing lamps. It replaces the bar that is original equipment on EG's, Road Kings, etc.
Old Oct 20, 2006 | 11:18 PM
dionne51's Avatar
dionne51
bdjhog,
Funny that if I do a search for accessories for an '07 SG this item doesn't even show up. Looks like what I need, appreciate your post. Added to the Christmas wish-list.
Thanks again,
D
Old Oct 20, 2006 | 11:22 PM
bdjhog's Avatar
bdjhog
ORIGINAL: shortleg
Also are these something the average tool guy can do.
I was hopeing that Harley would make something that would be plug and play.
Thanks
Shortleg
A manual would be beneficial for installing these. It's pretty straight forward, but if you don't know how to remove the ignition switch it can be a little trick to figure out or have someone explain to you in an e-mail. The other tricky part is removing the pins from the stock turn signal wires in order to be able to remove the wires from the housing. I ended up using a very small finishing nail, but the manual refers to some special tool. Those are the only two parts of the installation I think you need the manual for. The rest you can figure out with common sense and following the directions with the kit.
My suggestion would be to take the money you are considering paying the dealer to install these with and buy the manual for your bike. It will pay for itself in just one or two DIY jobs.
Old Oct 21, 2006 | 12:35 PM
Abnmarine's Avatar
Abnmarine
ORIGINAL: asuperheat
Here you go.
Old Oct 27, 2006 | 07:22 PM
ldr999's Avatar
ldr999
just purchased the passing lamps for my SG from the dealer; doing the install myself (dealer wanted $378 for passing lamps and rear crash bars) is there anything special I need for this install?
Thanks,
Lyn in ATL
Old Oct 27, 2006 | 07:40 PM
shortleg's Avatar
shortleg
Ok how do I get someone to tell me or what ever they feel good about to
let me know how to do the ignition switch removeal so I can do the aux lites.Also do they
come with another switch that will fill one of the blanks?
Thanks
Shortleg[Dave]
Old Oct 27, 2006 | 07:47 PM
Bryan TTM's Avatar
Bryan TTM
here's mine...i like em
Old Oct 28, 2006 | 12:16 AM
DI75's Avatar
DI75
